[B]Parking lights not working?[/B]
Old 09-01-08, 08:54 AM
shonuff53
shonuff53's Avatar
Default [B]Parking lights not working?[/B]
checked bulbs and fuses, and wires and still cant find the answer. well read this hopefully its your fix.
I have posted on other threads saying I would find a solution when I had some time to fix the burnt diode problem. If you dont know which diode Im referring to dont worry I have pics (its located up and to the left of your kick panel fuses). for tools you'll need a screwdriver, a lighter, needle nose pliers, a small sharp knife, and wire crimps. for supplies you need 2 male end wire connectors for 18 gauge wire, a couple small pieces of shrink wrap for 18-14 gauge wire, and a diode that can handle your volts/amps and etc.
remove these trim pieces to facilitate the process..
Attached Thumbnails [B]Parking lights not working?[/B]-car-0108-088.jpg
Old 09-01-08, 09:03 AM
shonuff53
shonuff53's Avatar
disconnect battery, and remove relay to the left of diode (note its position for ease of installation later on) , cut as much excess burnt plastic of where the diode use to be with knife, the pliers can help pulling the plastic off as well, once you've exposed two pins pull off the little pieces of metal connector until just the pins are exposed.. I need a tutorial with CL..
Attached Thumbnails [B]Parking lights not working?[/B]-car-0108-089.jpg
Old 09-01-08, 09:06 AM
shonuff53
shonuff53's Avatar
here is a pic of where the diode is with the new one installed, sorry I didn't get the pic before I put it in..
Attached Thumbnails [B]Parking lights not working?[/B]-car-0108-093.jpg
Old 09-01-08, 09:12 AM
shonuff53
shonuff53's Avatar
next I used these rectifier diodes from radio shack, all you need is one, bend the ends down together about a cm apart, slide on some heat shrink leaving enough of the diode ends exposed to install and crimp the 2 male wire connectors, once installed bend the ends of the male connectors open enough to slide over the pins in your car, and place heat shrink over the male connectors to be flush with the ends so that they dont contact when installed..
Attached Thumbnails [B]Parking lights not working?[/B]-car-0108-094.jpg
Old 09-01-08, 09:21 AM
shonuff53
shonuff53's Avatar
install the diode on the pins with the line on the left side (note picture), then reinstall relay to the left of it ensuring it (diode) stays connected. at this point feel free to connect battery to check that it is in deed working. if it is not working check connections with caution if battery power is still on. look over steps check that nothing was missed. once complete install everything back to normal configuration. and good luck... Gabe.
Attached Thumbnails [B]Parking lights not working?[/B]-car-0108-092.jpg
Old 09-01-08, 09:25 AM
shonuff53
shonuff53's Avatar
if you have a better way, please share, this way worked for me, after driving around for two weeks lights are still in good working order. hope this helps.
Old 09-03-08, 02:43 AM
re-rx7
re-rx7's Avatar
Great write up!!! What was the total. Looks like you did a great job looking around!
Old 09-06-08, 08:19 PM
shonuff53
shonuff53's Avatar
total was nothing the rectifier diodes plus some shrink wrap I already have, no more than $10.
Old 09-07-08, 04:37 PM
sc250tt
sc250tt's Avatar
I got my doide from my 97+ spare fusebox, worked fine .You should be able to get it at your local dealership for dirt cheap.
Old 09-09-08, 05:13 PM
shonuff53
shonuff53's Avatar
I honestly didn't even try to get it at the dealer after another member on CL said a dealership told him that its not even on there schematics, and what was left of it was melted to crap on my panel.
Old 09-10-08, 08:59 AM
re-rx7
re-rx7's Avatar
my diode was fine and my parking lights still dont work?? WTF!!
Old 08-23-14, 12:26 AM
jgdynamics
jgdynamics's Avatar
sorry to bump this thread, but which rectifier diodes did you use?
Old 08-23-14, 01:41 PM
dogwisper
dogwisper's Avatar
He originally posted this in 2008 so you may not get a quick reply...the package he posted says 276-1661 Radio Shack which is a 6 amp 50 volt rectifier diode sold at Radio Shack in 2014 for $2.99 package of 4. Before you ask... the next step you should do is go to the Radio Shack website to purchase these...
Old 08-23-14, 06:20 PM
jgdynamics
jgdynamics's Avatar
cool. i couldnt read the packaging on his picture... might be my monitor. I did check radio shack, i just wasnt sure which one it was. thanks
Old 08-27-14, 02:45 PM
BAD954BOI
BAD954BOI's Avatar
so this will solve the issue im having where the tail lights & parking lights don't turn on unless the light switch is in the auto position?
Quick Reply: [B]Parking lights not working?[/B]
