Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300
Thread Tools Display Modes
Old 03-08-01, 09:45 AM   #1
SC300TURBO
Trader Score: (2)
Send a message via AIM to SC300TURBO
Just so you all know...toyomotos last sc300 they did with the T62 turbo laid down like 600 rear wheel hp with the cast iron manifold....so it flows plenty...had mine for 2years now with no problems.....as far as the heads...toyomoto is using a 2JZ-GE motor in his drag car...fun fun....Jeff
__________________
2007 Ford Expedition EL Limited
2004 Jeep Wrangler Rubicon
1989 Nisan 240sx/Silvia 1JZ
No current Sc300...but definitly a OG sc300 turbo club member
SC300TURBO is offline   Reply With Quote
Old 03-08-01, 12:45 PM   #2
jbrady
Trader Score: (0)
Wow, 600rwhp with a 62-1. Is this confirmed or rumor? The compressor map for the 62-1 show the PEAK possible output to be apx 70lbs of air/min. Lbs of air/min times 10 is about the power available. So this would mean 700hp MAX. Max at 15psi would be apx 600hp at 65% compressor efficiency (getting low and hot). At peak efficiency you have 450-475hp at 76% and 75% compressor efficiency respectably.
See map here: http://www.turbocharged.com/catalog/compmaps/Fig10.gif
BTW, the 60-1 peaks at apx 650hp but is more appropriate in the 500hp range. Max at 15psi and 65% efficiency would be apx 550hp. Remember these are flywheel numbers and you would need to subtract about 50hp for manual car and about 70hp for automatics for the rwhp number.
60-1 map here: http://www.turbocharged.com/catalog/compmaps/Fig9.gif
__________________
99 LS400 Alpine Silver
1/4 stats: 14.22et 99.38mph
jbrady is offline   Reply With Quote
Old 03-08-01, 01:42 PM   #3
Ebanks
Trader Score: (0)
Send a message via AIM to Ebanks
Thumbs up My Car.
Damn, 600+ RWHP on the 62 in nice....
We are hoping my car will do 650 RWHP on just the turbo, and I also have that 120 shot on the car, but we may jet it up to a 200 shot before the end of this season.
Honestly guys, I am dumping a lot of money into my car, and I will be lucky to get like 100 more RWHP than what I had before.... I mean, if I would have put the larger exhaust housing on the 60-1 and sprayed the 120 shot I could have been close to if not slightly over 650 RWHP, and now I am hoping to hit 750+ RWHP (although, that is not what I am expecting, that is what I am hoping for). Is it worth the extra $20kish I am dumping right now? To me it is...
I wanted a stainless header for one thing, and I am having to put a lot more money into a beefier tranny and engine management, but whether it is worth the cost is always up the individual. I like custom stuff, because I like being different
This post was really pointless, I just thought i would post what I had in my mind after reading all of this... Feel free to ignore it
-Ethan
__________________
98 Panoz AIV Roadster
05 VW Touareg - V8 - Black/Teak
08 Subaru FSXT
Ebanks is offline   Reply With Quote
Old 03-08-01, 01:46 PM   #4
LexusRules
Trader Score: (0)
LexusRules's Avatar
Send a message via ICQ to LexusRules Send a message via AIM to LexusRules Send a message via Yahoo to LexusRules
Jbrady - You continue to amaze me
Scott - i think i'll learn my car inside and out within 4 years, so i should be able to do it myself, well with a couple buddies, and by then i hope to have an ultimate garage too.... okay thats a dream.... but i do!
__________________
Sasha
- 1997 240sx
LexusRules is offline   Reply With Quote
Old 03-08-01, 08:27 PM   #5
Snd Performance
Guest
Trader Score: ()
Posts: n/a
Quote:
Originally posted by SC300T
You'll need the Supra TT inline fuel pump. Unfortunately, you'll need a custom or TT? (don't know if the TT intake works on the NA head) intake system as well because the header puts the turbo high up in the way of the stock intake.
Actually the stock intake will work fine, the turbo is not in the way......... close, but it clears.
Lar
SP
Old 03-09-01, 11:37 AM   #6
v300
Trader Score: (0)
Default VVT-i
Guys (with turbo upgrades),
Are your engines VVT-i or non VVT-i? Does Toyomoto or SP have a Turbo setup that works with the VVT-i based 2JZ-GEs? Hows your experiences with them? SC300T mentioned that going past 9psi would require sometype of Air-Fuel Regulator such as the A'Pexi S-AFC or HKS S-AFC. Is that enough for pushing say 1.4 bar (20psi) without a VPC? I was told that the VPC will not work on the VVT-i engines with the electronically controlled throttle and that I would have to wait for HKS new stand alone computer.
Now here's my dilemna: I converted my car into a Aristo V300 (stage one). Now I want to take another step by upgrading to a single turbo setup. I have a '00 2JZ-GTE w/ VVT-i and the V300's ECU, wiring harness, four speed tranny, Supra/Aristo Fuel Pump, Supra 550CC injectors, fuel return line, and upgraded to a single turbo utilizing a combination of Sard's stainless steel manifold, XS-Engineering's Garrett-based T04X (w/.70 A/R), HKS 50mm racegate with gate set at .6-1.0 bar, and a pretty buff GReddy FMIC. Problem is that I cannot get my hands on an upgraded ECU/program. I am waiting in line for a HKS F-Con Pro V stand-alone computer (however the damn thing has been recalled for the third time).
Along with a good boost controller (HKS EVC Pro) can I boost 1.4 bar safely without a program? The best thing (caveman) I can do is to obtain some type of air-fuel regulator such as the APex'i or HKS S-AFR.
What do you guys suggest? My goal is to put out 500 at the crank with room to upgrade in the future. My car ran fine as a left-hand drive V300 but I want more kick. Based on the similar Supra TT's stock fuel system (550cc injectors) and auto tranny what is a reliable hp output I might be able to utilize "reliably." I really appreciate the help.
v300 is offline   Reply With Quote
Old 03-11-01, 07:08 AM   #7
SC300TURBO
Trader Score: (2)
Toyomoto has turboed several 2jz-ge vvti motors in the is300 and 99 gs300..he uses a haltech and has them running great with all daily driving handled fine...and it costs about the same as a VPC GCC combination....actually now that i think about it he put a hatech on a aristo motor that went into a lexus sc300 with a single upgrade so it can be done..give them a call 305-599-3050 Jeff
__________________
Old 03-11-01, 05:15 PM   #8
v300
Trader Score: (0)
Default VPC can work w/ electronic throttle?
SC300turbo,
Thanks for your input. I have tried calling Toyomoto, but all I get is an answering machine. I hope the Haltech is what it is cracked up to be.
Old 03-12-01, 12:58 PM   #9
SC300T
Trader Score: (0)
I've heard that the Haltech is pretty slick once it is working, but Warren Chang (A Supra owner and SupraForums.com moderator with the Haltech in his car) said its extremely difficult to install.
__________________
Scott Hureau
1992 SC300 5spd turbo - T60-1
2009 IS250 AWD
2002 LX470
1966 Mooney M20E
The project:
http://www.datapathusa.com/sc300.html
SC300T is offline   Reply With Quote
Old 03-12-01, 01:12 PM   #10
Ebanks
Trader Score: (0)
Scot-
I had heard the same thing about the Haltech.... I was told that for a daily driver it was definately not the management to go with, and that it was very difficult to get it running right.
I had heard things about cold startups not being all the smooth with the Haltech also....
Also, does the Haltech correct for altitude, temperature, etc.?
-Ethan
__________________
08 Subaru FSXT
Old 03-12-01, 01:15 PM   #11
v300
Trader Score: (0)
Default :(
SC300TURBO,
I just spoke to Phil at Toyomoto. They have never had the oppurtunity to work on that engine according to Phil. He also said that they have not been able to put a VPC on obd-II engines.
Old 03-12-01, 01:23 PM   #12
SC300T
Trader Score: (0)
Ethan,
Any ideas how much SP would charge for just the HKS VPC GCC + installation?
I'm really considering this route as a first step at controlling fuel, but want to go with a shop that has done it before.
How have your experiences been with SP?
P.S.
Just passed 4k miles since the N/A to T60-1 conversion and all is bliss... Have driven in virtually every condition imaginable. Definitely a steetable setup and great as an every day driver.
__________________
Scott Hureau
2009 IS250 AWD
2002 LX470
1966 Mooney M20E
The project:
Old 03-12-01, 02:39 PM   #13
Ebanks
Trader Score: (0)
Scott-
Im not sure how much Larry would charge honestly... The reason we didn't go with the VPC/GCC combo on my car is because you can't go larger than a 550cc injector that way, and that was not big enough for my needs.
2 or 3 weeks ago Larry told me that he had like 6 VPCs in stock, so you may want to drop him an e-mail and ask what kind of price it would be... His email is:
xxsupraxx@aol.com
BTW, you can go a LONG ways with the VPC/GCC setup... Larrys car is running that and look at his 1/4 mile time... On rough tuning!
Drop him an e-mail and let us know what he has to say about it!
-Ethan
__________________
08 Subaru FSXT
Tags
1jzgte, 2jz, 2jzge, 300, cast, downpipe, iron, is300, kit, log, manifold, safc, stage, style, supraforums, toyomoto, vpc
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
