SC- 1st Gen (1992-2000)
SC 300/400 Differences?
Old 06-26-07, 09:02 PM
zygotesoup
zygotesoup's Avatar
Default SC 300/400 Differences?
I realize that all this information is probably located in a number of different places around this site and I would be more than happy to search around and learn as much as I can (which I will do when I have time), but I need to pick up a new car soon, so I'm short on time. Can someone just give me a basic comparison between the SC400 and SC300? I had an SC400 and I loved it! It had over 360k miles on it when I sold it and everything still worked fine I want to pick up another SC4, but I've seen a lot of SC3's around and im wondering if they are as reliable ect as the 400. If anyone could give me a quick run down of the pros and cons of the 400 vs. the 300 I would really appreciate it. Thanks!
and if anyone wants to know anything about the MR2 spyder, I'll tell you everything you ever wanted to know
Old 06-26-07, 09:17 PM
DriftGirl
DriftGirl's Avatar
sc400 =
v8 with auto tranny
SC300=
6 cylinder lugging around the same heavy *** car...but some come with 5spd if youre into that sort of thing.
everything else is pretty much a non issue IMHO
Old 06-26-07, 09:20 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
Hi, welcome to the forums.
Ok...quick and easy
SC300 are very good cars as are the 400's.
Here's the question you have to ask yourself...
Do you want it to have a 600hp daily driver kill everything on the road car.
SC300
Do you want a great long lasting (as you already know) touring coupe?
SC400
Now, it wont take you very long using the search button at the top of the page, use "google" type key words and search the SC300/SC400 forums for a more in depth view of each model.
Old 06-27-07, 07:17 AM
zygotesoup
zygotesoup's Avatar
Alright, thanks guys... that helps. Are the 300s really that under powered? Power is not a huge concern for me, but if its really an issue, then I'm gonna have to go for another 400. Thanks again for your input.
Old 06-27-07, 07:22 AM
DriftGirl
DriftGirl's Avatar
Yeah, Sounds like you're in the market for an SC400.
Good luck with the search
Old 06-27-07, 07:25 AM
King7Two
King7Two's Avatar
They arent race cars.
But the 300 has the most potential.
If you keep your foot out of them, the get okay gas milage.
I personally have the 300 and love it. Its my daily driver for now, but in a few months I will pick up a new daily and put this one up......to be built.
Old 06-27-07, 07:59 AM
sc250tt
sc250tt's Avatar
ive owned both .both cars have the same potential .the sc400 has bigger brakes than the sc300 comes with a lip and wing .if you plan on doing a engine swap the sc300 should be a little cheaper consideing you dont have to change the radiator driveshaft powersteering lines ac lines etc sc300 are nice if you plan on doing a na-t kit .400 are better because the are more powerful out the box and when you do a tt swap its faster than the sc300 because of the v8 gear ratios
Old 06-27-07, 08:10 AM
zygotesoup
zygotesoup's Avatar
i plan on doing none of the above... i have the spyder for doing all the engine swaps etc for... this is just going to be a daily driver
Old 06-27-07, 09:20 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
If this is your plan, then 400 hands down.
Old 06-27-07, 09:42 AM
zygotesoup
zygotesoup's Avatar
thats what its looking like. thanks for the help with the decision guys, ill let you know what i end up getting.
Old 06-28-07, 01:58 AM
Ali y0
Ali y0's Avatar
sorry to thread jack, but the sc400 has larger rotors?
Old 06-28-07, 05:48 AM
WICKED 1
WICKED 1's Avatar
i thought a couple people posted that they didnt have to change driveshafts or radiators in a swap. just had to reloacate the power steering tank and water pump?
Old 06-28-07, 08:37 AM
ProjectLex
ProjectLex's Avatar
There are better threads for this discussion (ask engine and swap questions in the performance section of the forum), but what swap are you referring to? What engine into which model? Check my thread on some of the issues I ran into with a 1jzgte into a 94 sc300. The drive shaft will need to be replaced or modified (marriage of two different shafts) in some swaps.
https://www.clublexus.com/forums/sho...d.php?t=285515
Good luck if you go for it!
Old 06-28-07, 08:50 AM
raceonusa
Former Vendor
raceonusa's Avatar
According to autos.msn.com the V6 SC300 and V8 SC400 get the same MPG.. How strange..
Old 06-28-07, 08:57 AM
DriftGirl
DriftGirl's Avatar
If they called it a V6, I 'd take their factswith a grain of salt
Quick Reply: SC 300/400 Differences?
