SC- 1st Gen (1992-2000)
How to Deline Headlights
Old 06-10-07, 07:06 AM
Classified
Classified's Avatar
Looks sharp.
Old 06-10-07, 08:21 AM
JSC300
JSC300's Avatar
great write up, very helpful on where the 10mm screws are located! has anyone ever removed the headlight with the intercooler piping in the way though?
Old 06-10-07, 08:47 AM
RedPhoenix
RedPhoenix's Avatar
good job man!
Old 06-10-07, 09:42 AM
chingpo05
chingpo05's Avatar
not a big fan of this, but great work!!!
Old 06-10-07, 10:18 AM
DriftNsc3
DriftNsc3's Avatar
Nice job man! Great write up.
Old 06-13-07, 09:09 AM
mr29rose
mr29rose's Avatar
well i took off my headlight to try to scrape of the burnt area of the little parking light bulb. by accident i pushed to hard and the plastic tube popped off insie and there is no way to get it out now.
so i have no choice but to pop it in te oven to open er up to remove the lastic tube.
i will decide if i scrape away the burnt plastic on its inside or just remove the tube completly and just close of that area.
the piece with the bulb that is long, i will just saw it down and use the base to seal it off.
Old 06-13-07, 09:10 AM
mr29rose
mr29rose's Avatar
i figured if you reheat it, than you can squeeze them back together using the original adhesive, but i guess the silicone is just a precaution. so i will line the entire rim with silicone just incase etc
i just hope it seals ok and no fogging get in there.
Old 06-13-07, 10:37 AM
mr29rose
mr29rose's Avatar
just opened mine up. i suggest the 300 degrees. it works fine and is easier to pry apart.
also, i beleive there are 3 little screws on the 1997 year design that need to come out first. one near each side and one kind of hidden in the center near the edge.
the clips were a little issue getting back on, but i eventually got them.
i squeezed the unit back together and siliconed the best i could. i hope they dont fog up or condensate. if they do, oh well, ill just get new headlights at te junkyard
Old 06-28-07, 10:53 AM
Trippinond
Trippinond's Avatar
All you need now are some HIDs. They would look awesome in those projectors.
Old 06-29-07, 11:56 PM
pnyboy27
pnyboy27's Avatar
okay..sorry for the long wait..but here they are..a few pix of them both done..i finally had some freetime to work on them..ill put up a few more pix when the weather's nice and not raining so i can clean my car and take nicer shots..and i know..i need to lower my car..my springs should be coming in soon..so dont worry..=)
Old 06-30-07, 11:32 AM
RCThrine
RCThrine's Avatar
and runnin FNo1's.... looks hot... now slam that bad boy.
Old 06-30-07, 12:55 PM
Blizzy
Blizzy's Avatar
No offense, I think that looks brutal...just my opinion. I definitely commend you the work and the write up. These types of threads are all about the spirit of modifying.
Old 06-30-07, 09:44 PM
mungrin
mungrin's Avatar
I didnt like em at first but now i see those new pics i think its hot!
Old 06-30-07, 10:52 PM
RedPhoenix
RedPhoenix's Avatar
have a pic without flash in the day time?
Old 07-01-07, 10:57 PM
pnyboy27
pnyboy27's Avatar
ill be taking pix tomorrow..i just washed n waxed my car today and the weather's supposed to be nice..so ill be taking pix of the "new" headlights..and thanks for all the feedback!
Quick Reply: How to Deline Headlights
