door lock actuator
Old 04-01-07, 03:24 PM
tuninghaus
tuninghaus's Avatar
Default door lock actuator
any one know where the door lock actuator/s are for the SC300/400?
my driver side door doesn't lock with the power locks (have to do it manually with my hand). i pulled the door panels off and inspected the locks and cable which looked fine.
any cure or fix to this problem? the passenger works perfectly fine.
thanks
Old 04-01-07, 03:50 PM
RalAegidius
RalAegidius's Avatar
I have factory service manuals for my SC300 so I will check when I get home.
Old 04-02-07, 03:43 AM
Mr.Phreak
Mr.Phreak's Avatar
They're part of the locking mech
Old 04-02-07, 10:15 AM
tuninghaus
tuninghaus's Avatar
part of the locking mechanism, meaning it's in the door somewhere? or? do you know exactly where it is?
Old 04-02-07, 11:04 PM
Mr.Phreak
Mr.Phreak's Avatar
Just trace the wires, and you'll find it.
Old 04-02-07, 11:26 PM
tuninghaus
tuninghaus's Avatar
****! that looks like a pain in the *** to replace/ or pretty pricey...
Old 04-02-07, 11:59 PM
RGW LLC
Former Sponsor
RGW LLC's Avatar
it's very easy to change....i mean if you have done it before....or take it to a shop and let them do...if you need that aculator part, we have it in stock...please PM us for details..thanks
Old 02-07-14, 11:30 PM
TonyN
TonyN's Avatar
Bump.
I need the passenger side door lock/actuator assembly.
Old 02-08-14, 09:40 AM
asquires
asquires's Avatar
so neither of my sc400 outside door handles work, i already know its because that metal rod broke but i was wondering if there is any quick fixes or do i have to get another actuator?
Old 02-08-14, 11:18 PM
oldManTan
oldManTan's Avatar
my passenger side lock doesn't lock all the way. when i press the lock button the lock switch moves a little but not all the way. what exactly is the problem there? it locks fine manually just not with the button.
Old 02-10-14, 04:43 PM
TonyN
TonyN's Avatar
your screwed, get a another actuator
try looking at the clip on the door handle and make sure it has enough tention, it might also be that your actuator might be slowing going out.
Old 02-10-14, 07:21 PM
SEIDO
SEIDO's Avatar
Trust me it's a PITA to change.
DON'T BELIEVE THAT ILLUSTRATION ABOVE!!!
IT'S MISSING INFORMATION. HERE'S "WHY" …
I did it on my passenger side, and now I have to do it on my driver side.
The window-track is in the way of the unit; so getting it in there (or taking the old one out), and onto the door, is the hard part; 'cus it's too big to fit around the track. So you have to fight that whole actuator unit into place, around a few inches of space only, WITHOUT bending the window-track.
It doesn't take long (IF you've done it before …) but you'll get pissed-off the first time. It's not a fun job.
Old 07-08-14, 04:59 PM
Kris9884
Kris9884's Avatar
Well I am doing this as we speak and am at a stand still, I have everything unhooked and its ready to come out but it wont budge out from behind the track on either side, only slides up and down... Are there any tricks to getting this out besides removing the window and track??
Old 07-08-14, 08:11 PM
Kris9884
Kris9884's Avatar
Wow, so far, that was the worst experience I've had with my car.. The hardest part was getting the far screw back into the handle while trying to get around the window track. I feel like I gave myself carpel tunnel just after tonight.
BUT, that being said, finally, my girlfriend can open her own door haha
Old 07-08-14, 10:44 PM
oldManTan
oldManTan's Avatar
where can i get the actuator part? my locks just budge a little when i press the button. they never lock or unlock fully. can you fix the old actuator or is the only way to fix it is get a new one.
Quick Reply: door lock actuator
