SC- 1st Gen (1992-2000)
Fog lights out... not fuse or bulbs
Old 08-19-14, 09:10 AM
Shayy
Shayy's Avatar
I also have same problem with my 98 SC.
Old 08-21-14, 04:07 PM
crenfro
crenfro's Avatar
So I got the continuity tester out, I have power at the fog lamp fuse, but no power at the plugs. WTF is wrong?! This is frustrating.
Old 08-22-14, 07:13 AM
Teal Sc400
Teal Sc400's Avatar
Everyone having this problem should check the clasp bar. Grounding the bulb and must be closed properly, by making contact with the metal piece on the bulb for the fog light to operate/work.
Old 08-24-14, 07:39 AM
dogwisper
dogwisper's Avatar
It looks like all of the other obvious causes have been covered but I also notice most of these SC's with this problem have been lowered considerably from stock. The wires to the fogs run in the wheel well so if you bottom out you hit that harness. I would check there as well for rubs or breaks.This is a DIY to relocate the harness.
https://www.clublexus.com/forums/sc-...elocation.html
Old 08-24-14, 10:22 AM
crenfro
crenfro's Avatar
That's what I'm worried about since I'm lowered a considerable amount. I'll check that out later today while I'm changing my rotors!
Old 10-12-14, 12:13 PM
crenfro
crenfro's Avatar
So I've still been having troubles with these damn fogs. Cannot get them on. I don't have power to the plugs and I don't even have power to the fuse....
I just went and bought a brand new Toyota OEM fog light relay, replaced the fuse (wasn't even blown), and bulbs. So now the only thing I can think of is the actual switch on the headlight stalk. I have no idea how to fix this....
But just to clarify, this is the correct fuse for the fog lights? Because when I test it I have no power there with the switch on.
Old 12-29-14, 03:14 PM
PJSC300
PJSC300's Avatar
i have the exact same problem on my 95. Have their been any resolutions yet?
Old 03-10-15, 09:33 AM
jessemeza0
jessemeza0's Avatar
Default 1998 sc300 fog lights
Hey yall.
My fog lights on my 1998 SC300 wont turn on. i checked the fuse and it is fine. i even checked the bulb and it was ok.,
anyone had this problem? what did yall do to fix it.
Old 03-10-15, 11:01 AM
crenfro
crenfro's Avatar
Originally Posted by jessemeza0
Hey yall.
I ended up just saying F it and did it my own way. I bought some HID's and made my own wiring harness to my own switch and just forgot about the original wiring all together.
Not for everyone but I didn't feel like messing with it anymore when I knew I could just run it my own way.
mrfresh
10-06-14 01:38 PM
khutch
11-10-09 01:17 AM
marito98
IS - 1st Gen (2001-2005)
06-01-08 10:57 PM
is250al
02-08-08 10:46 AM
olddog
GS - 1st Gen (1993-1997)
03-29-06 10:02 AM
Quick Reply: Fog lights out... not fuse or bulbs
