SC- 1st Gen (1992-2000)
Power side rear view mirrors don't work
Old 10-08-06, 10:44 AM
rad5446
rad5446's Avatar
Question Power side rear view mirrors don't work
1992 SC 400. Side rear view mirrors stopped working. Apparently no power to mirrors. Checked fuses, but they were not blown.
Any ideas/solutions???
Thanks
rad
Old 10-08-06, 10:20 PM
Homchenko
Homchenko's Avatar
Ya, same problem here, took apart the switch, seems to be no problems there...
Old 10-09-06, 12:37 AM
0l33l
0l33l's Avatar
If you've got a friend with an SC try swapping out your mirror ECU. Its under the driver's seat.
Old 10-09-06, 08:31 AM
rad5446
rad5446's Avatar
Thanks. Don't know anyone with an SC.
Old 10-09-06, 09:30 AM
aliga
Former Sponsor
aliga's Avatar
i have one 45 shipped.
Old 10-09-06, 05:51 PM
jrmoskal
jrmoskal's Avatar
I just had my drivers seat apart the other day installing some new leather and i noticed the ecu under there. I thought that was just for the seat functions/memory itself. Never realized that controls the mirrors as well.... good to know.
Old 10-10-06, 07:32 AM
dsa2402
dsa2402's Avatar
Default Same
I have the same problem... Have you fixed yours yet? Also my passenger side window doesnt work. I hear it groan when i try and it flinches a little but thats it.... Any Ideas?
Old 10-10-06, 08:02 AM
techsc400
techsc400's Avatar
Mine does this also. I thought that it is a connection problem in the switch...
Hmm.. ECU...??
Let us know what it was.
Old 10-10-06, 11:10 AM
jrmoskal
jrmoskal's Avatar
The window issue sounds like the regulator is going out. Common issue unfortunately, do a search. There are some threads on here with a procedure to repair it yourself or you can PM Aliga or R&J Dist. They can sell you a nice used one.
Old 10-10-06, 12:34 PM
aliga
Former Sponsor
aliga's Avatar
mirror ecu is located under the dash not the seat.
Old 10-10-06, 06:52 PM
JohnEd
JohnEd's Avatar
Default mirror ecu
I had this problem and ALIGA solved it with a replacement ECU. It is under the dash and sort of in front of your right knee. Before I installed mine I plugged it in to the harness and just let it hang there. It worked so I pulled the dash apart and installed it. Aliga has helped me with a lot of problems and he has never been wrong. He responds quickly with good quality used parts.
Good luck
John
Old 10-10-06, 11:05 PM
RGW LLC
Former Sponsor
RGW LLC's Avatar
if you mirror doesn't work...then you need the mirror ECU box, which is located behind the radio and gauge cluster.....if you window doesn't work, then you will prob need the motor/regualtor assy.....
we got BOTH items in stock....thanks
Old 10-11-06, 06:50 AM
dsa2402
dsa2402's Avatar
Default Regulator
How much would a regulator assy cost me?
Old 10-11-06, 07:36 AM
Kilo
Kilo's Avatar
Gazi - I think I may need one too - my mirror just crapped out on me.
Old 10-31-06, 12:46 PM
rad5446
rad5446's Avatar
Anyone know what a mirror ecu costs?
Quick Reply: Power side rear view mirrors don't work
