SC- 1st Gen (1992-2000)
How many people have non working factory keyless entry?
Old 11-16-06, 07:52 PM
  #76
udfxrookie
udfxrookie's Avatar
ok... I bought a new keyless control module and it does the same as the old one. at 95.1 I get a silence in the stereo when pressing the button... no tone. I put the key in the antenna hole and tried it... still nothing... what now?
Old 11-17-06, 09:32 AM
  #77
fooldall
fooldall's Avatar
Yo, OLT- any info on removing that back seat and panel? What does inserting the key in the antenna and pressing the button do? Also, if it unlocks- what is the next step?
Thank you!
Old 11-17-06, 11:33 AM
  #78
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
why did you buy a new control module if you new the transmitter was faulty??
Old 11-17-06, 11:34 AM
  #79
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
Thank you!
pull up on the front of the back seat to remove. 4 screws on the bottom of the rear upper seat.
Old 11-17-06, 01:11 PM
  #80
udfxrookie
udfxrookie's Avatar
where's the transmitter located? Can I replace it?
Old 11-17-06, 07:02 PM
  #81
Supra Dr
Moving SC Threads
Senior Moderator
Supra Dr's Avatar
Originally Posted by O. L. T.
buy a new control module, or blame the prom IN the control module.
udfxrookie:
I think the confusion is if your getting the tone on the radio. The transmitter
is the key when you push the button.
Tone on radio = key is good - check module
No tone on radio = key problem - check/resolder connection as described
OR replace transmitter.
O. L. T. am I correct?
Old 11-17-06, 07:22 PM
  #82
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
I get the tone on 95.1 and tried putting the key in the antenna of the control modle and pressing the button and nothing happens... what now?
I think we are having a terminology problem here. Let's try this again.
If you got a tone on 95.1 your transmitter is GOOD. Thereby you should replace the control module. Seems like this is where we are right now.
Now that the control module is ruled out, we have to go forward from here with tests. You had to rule the control module out first.
OK, did you change the PROM out in the control module with your old PROM? The new control module will not have the same prom your old one did.
You'll see the screws on the side and a little door.
Old 11-19-06, 06:50 PM
  #83
udfxrookie
udfxrookie's Avatar
What PROM are you talking about and what little door? I've attached a pic of what I think your talking about....
Also let me try to get this all right:
1) Key is the transmitter
2) I don't get a tone but when I press the key button the radio goes silent which means key is good
If the above two are true I thought it ment the key module need to be changed. I changed the key module and recieved the same results on #2 above. Does this mean the key is bad? I also ordered a new key online and it didn't even make a tone, so I figured that key must be bad.
Now if I needed to swap out the PROM (which I have no idea is) from the old key control module to the new one, wouldn't I not have gotten the same result, #2 above, with the new key control module... I thought it wouldn't do anything, even silence the radio..
Sorry that I may have confused people, or if what I'm saying is really stupid, and thank you OLT for taking the time to break this down and help me out, you've helped me more times than I can count with all of your other posts to.
Old 11-19-06, 09:11 PM
  #84
udfxrookie
udfxrookie's Avatar
Old 11-19-06, 09:45 PM
  #85
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
I don't have my unit in front of me, but the basics are that the key and ECU there have a frequency they operate on. (if not anyone could use any key).
There is a prom (chip) in the ECU that matches the key. The prom is removable.
PS- judging by the table, somebody loves you.
Old 11-19-06, 09:58 PM
  #86
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
Man you're killing me, it's 31 degrees outside and I had to go to the garage! LOL
Here's the door, here's the prom. swap this with the one from your ORIGINAL unit.
Attached Thumbnails How many people have non working factory keyless entry?-dscn2101.jpg
Old 11-20-06, 07:02 AM
  #87
udfxrookie
udfxrookie's Avatar
Rofl, I see it... and yeah someone does love me, my wifey =) And man ohhh man does she need patience. I'll swap it out tonight and repost
Old 11-20-06, 07:35 AM
  #88
fooldall
fooldall's Avatar
Heck yeah, now THAT's What I'm talking about!
Great info!!!!!!!!
Old 11-20-06, 07:05 PM
  #89
Supra Dr
Moving SC Threads
Senior Moderator
Supra Dr's Avatar
Not only does he know his electronics, but he also
has a very keen eye! LOL!!
Old 11-20-06, 11:56 PM
  #90
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
Seems like I should mention this just .... because. You guy's that get tones, but no response do indeed have the remote button in the on position right? It's under the steering column on the dash, a switch.
Quick Reply: How many people have non working factory keyless entry?
