Electrical Problem
Electrical Problem
This is for the Electrical Experts in the forum..I have a small problem..I installed some different kind of taillaights in my 93 SC400..everything is working fine except for the turn-signal lights are coming on and off at a very fast rate..like there is a missing light..does anyone here know whether I should use a resistor or is there a heavy duty flasher unit I can use...?
Thanks for any HELP you can render..aftv
did u buy new tail lights or did u buy new bulbs?
i had this problem when i installed LED signals in my head lights, anytime i signaled (except when i put my hazards on) they would blink fast, it is because you are changing the resistance on the circut, if u want it to work properly use regular bulbs (that is if u went to LEDs)
try and put ur hazards on, does it blink normally?
Yes..all my lights work just fine including hazards..the only problem is the fast blinking when I turn on the turn signal...i'm using 1157 na bulbs..but the new tails only have 4 bulbs in them..instead of the 6 in the stock tails on each side..
thanks
thanks
4urxtc
SC- 1st Gen (1992-2000)
33
04-24-11 05:32 PM
