My Gas Mileage Is Killing Me!
I have a 93 sc300 and im getting almost 15 miles per gallon but im in the city. I think im taking it easy on my car not letting it go past 3 grand on the tach but it seems like my gas mileage just seems to be killing me no matter what. What do i do, is this normal. SOmone help me out
uhh fuel filter change, tune up, fuel injector cleaner (ie. techron), alignment, tires(good treadwear/tire pressure), and also you may try synthetic oil (engine,trans., and diff.). thats all i can think of at the moment.
I get about 15mpg as well, all city driving. I haven't done a tune-up in a while and I'm due for an oil change. I feel that when I change my plugs, cap, rotor, and fuel filter I will be up around 17-18 mpg city, but who knows. Also I have a lead foot.
Banned - could not follow forum rules
Get a good tune up first, check tire pressure, and dont ride the rpm's too high... Also if you can get high flowing cats and mufflers and a K@N intake filter. Do all that you will see a very good increase in gas mileage, gauranteed...
Other very unlikely causes of gas compsuption would be a small fuel leak, but you would probably smell something, other would be a fouled ECU that is running the car too rich, very unlikely and the engine would run different....Good luck...
City driving kills my MPG. I get around 16 around town.
Out on the highway, I get about 26. Much better.
If you have to change your driving habits because of gas prices, this car is definitely not
for you. A econobox 4-banger is probably a better choice.
One little thing that improved my MPG was turning on the PWR ECT. Weird, considering
it increases RPM gear changes. But I swear my car not only runs better, but spend less
at the pump. YMMV.
at the pump. YMMV.
Straight city driving = 14-16mpg
Highway = 22-24mpg
Thats what Ive gotten so far from my Sc300, 5spd. Seems to be very common to get around those values. It is alot of weight to haul around and the 2jz isnt exactly efficient by any means.
Highway = 22-24mpg
