SC- 1st Gen (1992-2000)
Tune up/ Timing Belt
Old 08-31-01, 10:13 AM
sclextasy
sclextasy's Avatar
Question
wassup guys,
my sc400 has about 95000 miles on it, wut do i need to tune that bad boy up?? how much does it cost to change the timing belt and all that crap at the dealership? can i take it to a toyota dealer and do it for cheaper????
thanks jay
Old 09-01-01, 07:16 PM
VQT
VQT's Avatar
Any where you decide to go to, they will do the same work as long as you tell them what you want.
You need to tell them you want: timing belt, water pump, two idlers, cam seals, new park plugs, wires, caps and rotors...that's the minimum for my SC400
If you just tell the mechanic that you wanted timing belt change, he'll just change the belt...
Lexus dealer or Toyota dealer will charge the same for parts. Maybe cheaper for labor at Toyota.
Steve Ganz maybe the cheapest for parts that I know of. If you can get someone to do just for labor and you supply the parts, then buy parts from Steve Ganz.
I paid $300 for labor on the things I mention above.
About $700 for parts.
Old 09-03-01, 09:07 PM
Denis657
Denis657's Avatar
change a fuel filter also
Old 09-03-01, 09:13 PM
machinegt
machinegt's Avatar
the 30k and 90k miles lexus tune up is the 2nd biggest tune ups , the biggest ones are the 60k and the 120k miles , i would make sure things are taken care of, there is a spreadsheet of what things are done at each tune up that u can get from a lexus dealership, its a ton of stuff, so make sure u get ur tune up done well.
Old 09-04-01, 06:11 AM
TypeSC300
TypeSC300's Avatar
Default SCLEX
YOU SHOULD ALSO CHANGE THE COOLANT ALONG WITH BOTH UPPER AND LOWER RADIATOR HOSES, I DID IT TO MINE AT 85K. YOU SHOULD ALSO THINK OF THE DIFF AND TRANNY OIL.
liquidicy
Northeast
08-13-08 11:08 AM
sorka
Maintenance
06-01-08 01:13 AM
Lexson
Performance & Maintenance
08-12-04 03:40 PM
Quick Reply: Tune up/ Timing Belt
