So your door handle doesnt work - DIY w/ pics
Old 12-21-08, 07:18 PM
  #106
ShiftyD2k
ShiftyD2k's Avatar
nice.. anyone who know about install door lock actuator on passenger door??
Old 12-23-08, 08:33 AM
  #107
INDO
INDO's Avatar
good stuff... my passenger side went out yesterday and drivers side went out today. Hopefully this works out for me!
Old 12-27-08, 12:44 AM
  #108
ShiftyD2k
ShiftyD2k's Avatar
My friend have problem with power lock passengers side.. any idea?
Old 12-27-08, 02:21 PM
  #109
Cleanshots
Cleanshots's Avatar
Originally Posted by eroc75
Yeah, my Toyota dealership is acting like they can't get this damn part. Anywhere I can order it? Anybody know at all?
that little clip, i had spair ae86 doors in my back yard and on day i was striping the door and it uses those same clips, so im guessing any toyota with handles that must be pulled up uses those clips...
yea, go here.
Old 02-09-09, 11:04 PM
  #110
skurd3da1
skurd3da1's Avatar
Little plastic clip can be found at your local kragen and advance auto parts. Not exact the same but the one that I bought this morning works like a charm. $3 for five different kinds but the white one is the closest match. No need to order one from the dealership.
Old 02-10-09, 08:06 PM
  #111
Timo5701
Timo5701's Avatar
Ok so I had them same problem, broken outer handle clip. Loaned out my car & the jack *** just had to roll down the windows. Broke the rod to the latch new part is $280 from the dealer so I bought a used one for $50 & felt lucky. Oh yeah correct way to install new clip is clip in handle, rod in clip. Have fun!!
Old 02-11-09, 01:15 AM
  #112
SC34M3
SC34M3's Avatar
got mines at the dealer for $3 but that didn't work still. thinking of replacing the whole assembly...how do you removed the motor? sitting way in the back and don't see any screws.
Old 03-09-09, 07:55 PM
  #113
aka paco
aka paco's Avatar
thanks to CL and all the helpful posts.. just did this.
Old 04-12-09, 03:41 PM
  #114
dlrjr327
dlrjr327's Avatar
The white piece that is the most similar wouldnt happen to be the ones made for gm or chrysler would it?
Old 06-25-09, 07:47 AM
  #115
romeo291
romeo291's Avatar
Hey guys, forget about the plastic piece. I found a ghetto and even cheaper way to fix the problem. The end of my rod broke, and the plastic clip broke, but I was able to fix it with just some zip ties. All you have to do is place the arched end of the rod back onto the door actuator thing where it once was, you don't really need the extra metal part because it's mainly there to keep the rod attached to the door actuator (so that dumb people end up thinking they have to replace the whole door actuator when the rod breaks). Once you place the rod back on the perch that it goes on, place the rod in the hole and lasso a zip-tie around the hole and rod. I put two zip ties around it and secure it really tight, then I put another one at the end of the rod so that it doesn't fall off. It works like a charm. No need to remove the door actuator or anything (it was a pain in the *** to do, I did it just to find out I didn't have to). Anyways, my door opens just fine now, I've been testing it like crazy.
Old 06-25-09, 12:52 PM
  #116
yong32986
yong32986's Avatar
the end of my rod broke, been trying to find a way to fix it BEFORE my driver side breaks down. romeo291 Your way of fixing it seems nice and easy, but not really get the picture, Can you post some pics, tha will help me alot, thanks
Old 07-03-09, 06:03 PM
  #117
yong32986
yong32986's Avatar
finally got the door fixed, but not sure how long it will last. anyway, the rod end broke off like the others did, i turned the smaller "U" shape piece up side down and solder it to the rod , and stick it back to actuator, it works..
Old 07-11-09, 11:29 AM
  #118
poetik
poetik's Avatar
I just finished doing this on my passenger door. Honestly just like romeo said you can do this with just zipties and trust me it is a ton easier (on the wallet, time, and skill) than actually replacing the whole unit. After fixing it, my passenger door actually feels better to open than my non-broken driver's side.
Here is my whole process for fixing my passenger side:
1. Ordered the plastic piece for around $8 shipped off one of the links on this thread. (Came in a pair)
2. Took my door panel off.
3. Put the plastic piece into the hole where it goes to on the door handle.
4. Put the broken part of the rod onto the the opening mechanism.
5. Locked the rod into the plastic piece.
6. Pulled door handle and saw if the rod was actually doing its job in the door actuator.
7. Carefully zip tied the bottom part of the rod to a wire harness that's a few inches to the left of the rod. (That way the rod doesn't pop off of the mechanism)
It works perfect and all you need is the plastic piece and a pack of zip ties. I would definitely use the plastic piece for the hole because getting a zip tie around that is really hard unless you have childlike/feminine small hands.
Total cost: Around $10
Total time: Less than an hour if you know what you're doing.
Also gotta thank romeo291 for coming up with the idea. I was actually gonna buy a whole door actuator today until I saw your post.
Old 07-12-09, 06:10 AM
  #119
pioww
pioww's Avatar
bumpin this as I plan on fixing on mine today.
Old 07-12-09, 06:35 AM
  #120
romeo291
romeo291's Avatar
Nice work dude, the trick is definitely securing the rod to the mechanism, oh, I was also able to lasso zip ties to where the rod goes into that hole, you just gotta use needle nose pliers to loop an already looped zip tie over it and pull to tighten. It wasn't that hard. Lasso a few to secure it real good.
Quick Reply: So your door handle doesnt work - DIY w/ pics
