SC- 1st Gen (1992-2000)
Need help, brake feel too soft
Old 06-08-01, 07:01 AM
VQT
VQT's Avatar
How many SC owner have this problem, and how did you fix it?
My 93 SC400 brake felt very soft ever since I bought it 4 months ago. So far, I had bleed the traction control, all four brake calipers, change the master cylinder, adjusted the push rod...the brake still feel soft.
I don't want to change the brake lines to stainless steel yet, until I fix this issue.
Thanks,
VQT 93 SC400
Old 06-08-01, 11:27 AM
mindflux
mindflux's Avatar
simple question...are the pads new? Do you know how thick new pads are? they have a lot of meat. If the pads are worn out and u think they are ok u'll be in for a big surprise when u replace them.
Also check the master cylinder for internal leaks.
mind
Old 06-08-01, 11:34 AM
RealMarty
RealMarty's Avatar
Have you tried any other 93 SC400s? May be that what you feel as soft is the way the brakes are.
However, the brake lines may BE the issue. I've read in other posts how older stock brake lines can get a bit soft and, by expanding under pressure when you press the brake, causes the soft feeling. May be time to look at new stock brake lines or upgrading to stainless. I'm not an expert in this area but I'd check out the brake lines.
Old 06-08-01, 12:51 PM
DickLexus
DickLexus's Avatar
I had the same problem with my 92 sc400. I just had new front pads and rotors installed and the system bled. Now it feels great. I had the system bled twice before but it was still soft. i can't say what caused the correction but it is like night and day. My old rotors were real thin and warped. It might be the thicker rotors.
**** L
Old 06-08-01, 09:01 PM
VQT
VQT's Avatar
Mind, I already replaced the master cylinder and it still feel the same.
The pads on all four wheels are at least more than 5 mm thick; therefore, worn out pads are not the issue.
The rotors are also in good shape
Today, A Lexus mechanic friend of my brother suggested that I check the free play of the "Sliding Pin". Sure enough, I found one sliding pin frozen; I am having problem of taking this pin out, after this pin is out, clean, grease...I'll up date the problem. All other sliding pin are easy to slide in and out.
Old 06-09-01, 02:45 PM
stevenj
stevenj's Avatar
Default Soft brake pedal feel
You sure found the cause of your problem. You could have read about it here:
http://www.users.bigpond.net.au/star...wers2.html#Q40
Old 06-09-01, 04:57 PM
VQT
VQT's Avatar
Stevenj,
Thank you for the link
MX73
07-20-18 04:43 PM
BostonVP
04-10-13 01:58 PM
daweeze02
Suspension and Brakes
11-14-09 09:39 PM
acc
02-07-08 12:08 AM
VQT
Maintenance
03-15-01 05:14 AM
Quick Reply: Need help, brake feel too soft
