SC- 1st Gen (1992-2000)
Diagnostic code #25 !!!
Old 09-27-11, 06:52 AM
2 400's
2 400's's Avatar
Another thing I had good luck with is called " guaranteed to pass". You dump it in your fuel tank and it cleans out the system. Available in most auto parts stores. Now don't forget, code 25 is low fuel to air ratio, so you need more fuel. Good luck!
Old 09-28-11, 11:06 PM
chef05b
chef05b's Avatar
Originally Posted by chef05b
That's what I thought. Mine hasn't cleared yet so I got some mass air flow sensor cleaner. Going to try and clean it out in the morning. Someone suggested that there might be a vacuum leak and to spray carb cleaner around the intake to see where the leak is, if there is any. Hope the mass air flow sensor cleaner works, if not, I might have to take the injectors out and clean them.
Just saw the typo. I just got the zmax stuff so I'm going to try that first, before having to remove all the injectors and manually clean them.
Old 10-02-11, 02:44 PM
chef05b
chef05b's Avatar
Manually cleared the code last night but came back today after driving about 50 miles. Any one have any suggestions? I checkanged the fuel filter and cleaned MAF, also checked if there is a vacuum leak but so far no dice. Need help. Any suggestions would be great on what I should check next.
epd120265
RX - 1st Gen (1999-2003)
12-29-16 07:12 PM
Baraka
Canada
06-10-10 04:35 PM
Max Power
08-24-09 04:06 PM
calred34
03-04-09 03:02 PM
Christian8
16
11-05-06 11:22 PM
Quick Reply: Diagnostic code #25 !!!
