SC- 1st Gen (1992-2000)
How to: clear the AIR BAG light
Old 07-22-07, 11:23 AM
  #31
tritron
tritron's Avatar
will this reset abs light
Old 08-23-09, 07:49 PM
  #32
okbobbo
okbobbo's Avatar
Originally Posted by DaveMcKenz
I had almost given up. Some tips that worked for me:
1. Put ignition in ACC position with no contact to AB or Tc
2. wait 6 seconds by your watch
3. Contact ground wire to Tc...AB...Tc...AB for one second each. One second is longer than I thought, so use a watch to get the timing.
4. Contact and hold Tc to ground. The airbag light finally changed to rapid flickering and then went out.
5. Celebrate!
Good luck
This worked for me. Just had to keep trying to get the timing right. I was pleasantly surprised when the light started flickering. Used the paper clips and ground wire to the door spring bolt. Just a b***h to get the diagnostic plug back in the hole!
Old 08-24-09, 02:51 PM
  #33
terrylin
terrylin's Avatar
Is the airbag light and the SRS the same?
Old 09-11-09, 11:19 AM
  #34
okbobbo
okbobbo's Avatar
Default Replace diagnostic plug
I couldn't get the plug back in. There are four screws holding the panel under the dash. Remove the panel, replace plug, and replace panel. Done.
Old 09-19-09, 12:30 PM
  #35
6SOARER
6SOARER's Avatar
Has anyone cleared a code 41 for the airbag? I read that most of you had code 22 and cleared it with no problems but us guys with the 41, seems like no one has a solution. I got my instrument back from Lextech and after the install I got the airbag light. Checked the code and sure enough its code 41
I checked Alldatapro online and it says that code 44 is center airbag malfuntion. Where do I check? I never had any problems with this before..
Old 09-19-09, 10:33 PM
  #36
Amini9
Amini9's Avatar
thank god the 92 doesnt care about the airbag. mine turns off after a bit. LOL.
Old 09-20-09, 07:44 AM
  #37
6SOARER
6SOARER's Avatar
I have a 92 and the light is ON
Old 12-16-09, 01:03 AM
  #38
sc300jas
sc300jas's Avatar
i am getting a code 41 also, not 22 (which i originally thought it was). no one has the solution for 41 yet?
Old 12-16-09, 08:55 AM
  #39
twojayzee
twojayzee's Avatar
I joined TIS yesterday and DL'd some docs that will hopefull shed light on that very question. I havent had time to review it yet
Old 12-16-09, 12:14 PM
  #40
Amskeptic
Amskeptic's Avatar
I have heard that the ABS computer nanny sometimes wants you to do a normal diagnostic code read, TC to E1, before it will allow you to do the wire dance erase. Also, be aware that the erase is hampered by low battery voltage.
Colin
River2016 (03-19-23)
Old 05-17-12, 02:00 PM
  #41
RCGallegos
RCGallegos's Avatar
Default 2004 GX470 airbag light clear
I pulled my cluster with the key on. Unfortunately, now I need to clear my airbag light. But I can't seem to figure which plug is TC or AB to put wire in to ground. Do I just use the plug under the dash used to read codes? How do I know which are TC and AB? Please help.
Old 05-17-12, 03:52 PM
  #42
Cleanshots
Cleanshots's Avatar
whats wrong with you!?!?!?! why r u bumping old things? secondly this is the sc300 sc400 not a gx470 forum. OMG
2jzBrandon (07-08-23)
Old 11-09-16, 12:58 PM
  #43
GL123
GL123's Avatar
Default Resetting Air Bag Code 41
After installing a repaired cluster for my 92 SC400 the air bag warning light stayed lit and I got a code 41 and not a code 22.
I was able to reset it by following a similar tc-ab-tc-ab-tc sequence described in a DIY web page: "How to Turn-Off the Air Bag Light / Clearing Diagnostic Code 41 1990-1994 Lexus LS400". I managed to reset it in 2 tries.
Hope this helps those who get a code 41.
Old 03-14-23, 04:32 PM
  #44
Ethan5150
Ethan5150's Avatar
Default Air Bag Light Keeps Coming Back On
Hi folks,
I had this airbag light a while back when I rebuilt my cluster. I used the wire dance method to quickly clear it - thank you! But now the Air Bag light has come back on and this method doesn't clear it.
I do the wire dance and finish with TC connected to ground, then the ABS light blinks rapidly a few times and the Air Bag light goes out. Then it comes back on in three flashes, a pause, and one more flash. It will repeat this 3-1 sequence until I remove the ground wire from TC, at which point it comes back on solid.
Any ideas?
jus10ag09
02-16-10 07:39 PM
UR2klose
03-07-09 10:31 AM
katz
03-17-03 06:09 PM
Quick Reply: How to: clear the AIR BAG light
