My Intro to CL: This is how bad of a driver I am
Hi guys,
Finally getting around to introducing myself. Some pics of my ride and to show everyone how bad my driving is...for now. First time at the track w/ the new car/setup.
Boostlogic Stg2 Kit with supporting mods.
that was my best run for the day. remember, this was the first time at the track w/ this car. i could not get first gear to hook at all but i never played around w/ tire pressure at all. i wanted to see how it would do as set up on the street.
111.xx mph is pretty good- but you should be doing a bit more than that with a BL stage 2 kit with supporting mods. Are you still on stock compression, or did you lower it with a head gasket? How much boost? What transmission? Pump or race gas?
Seems like a nice setup- good job
still running stock w58 w/ spec stage 3+ and super clamp option.
not sure on hp but should be in the low 400's at about 18lbs w/ a t61. last dyno was at 8 or 9lbs and that made 310rwhp. still not fully tuned. i needed to shift early, around 6k rpms as car was running lean in the higher rpms at upper boost level. need to figure out fuel issue. this is on pump gas.
