1999 SC300 missing keys
I had the idea overnight that the trunk lock would be a much easier one to access for checking the key code, so I pulled back the panel this morning on the '98, which I know the code for. The trunk lock cylinder has the code in the same spot, mostly covered by the lock sensor. Unfortunately, it doesn't match the known code for the doors and ignition. The non-valet cylinders must be coded differently.
Luxor, any idea if the trunk key code is a subset of the door lock code, and if knowing one can be used to look up the other?
Reprogramming key
When I got my SC 400, it came with three keys: an original Master (everything worked), another Master (wouldn't start ignition but would open doors and rear hatch) and a valet. I had to reprogram the second Master and everything worked as it should. There is a series of steps to do this. If you do a google search, you'll find it.
Here's is one set of instructions (I had a different one also. Not sure this is the correct one). Good Luck!
Reprogramming Lexus key
Programing Instructions for Lexus Keyless Remote:
1. Start with key out of switch, driver’s door open, all other doors and trunk closed, doors unlocked.
2. Insert key in ignition, DO NOT TURN ON, and remove key.
3. Using drivers side power door lock button, lock and unlock doors 5 times within 40 seconds, ending with doors unlocked.
4. Close driver’s door and open it. Again lock and unlock doors 5 times within 40 seconds, ending with doors unlocked.
5. Insert key into ignition and turn from LOCK to ON to LOCK one time. Remove key from ignition.
6. Door locks will cycle one time.
7. Press lock button on transmitter for at least one second. Door locks will cycle.
10. Within 20 seconds, close drivers door and open it and press button on transmtter again for at least one second.
11. Door locks will cycle. Wait 20 seconds and registration will be completed.
**if it does not work, start over from beginning, it may take several attempts. If it does not work, contact your local dealer.
Keymam.com
TYPE B
Lexus Key and Remote Programming
Key Programming 1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your
key is programmed. To end programming step on brake one time.
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key.
If you have a master key then you will probably need to perform this procedure more quickly.
Remote Programming 1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove. Do not turn it on.
3. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
4. Close and open drivers door.
5. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock,Lock, Unlock, Lock, Unlock)
6. Put key into ignition. Turn to "ON", turn off and remove.
7. You will see the door locks cycle by themselves.
If the door locks do not cycle (lock and unlock) by themselves then the car isn’t in programming mode and you must start over.
8. On the remote, press and hold the LOCK and the UNLOCK button at the same time for no more than 2 seconds.
9. On the remote, press the LOCK button for no more than 1 second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted.
IF the locks cycle twice it has failed.
The most common reason for programming failure is because the car didn’t receive a good signal from the remote. To fix this problem try these tips. 1) Stand outside of the car while you are performing steps 8 and 9. 2) Don’t hold the remote buttons down as long.
As long as the car is still in programming mode you can keep trying steps 8 and 9 until you complete the programming. If you wait too long and the car exits the programming mode then you must start over.
After you get the remote to program then continue on with step 10.
10. Close and open door to end programming procedure.
Keymam.com
TYPE B
The dealer told me the only way they cut keys is from the VIN. They cannot create a key from an existing key. They gave me my money back so I was not charged. They did try to "trace the key". I guess a computer can read the key. It came up with nothing on the valet key which he told me was odd.
Maybe I should go to another dealer?
You should try going to another dealer since every dealer is a little different.
If I remember correctly there was a shop online that offered this service. By sending them your vin and they had the ability to recut new factory keys from it for about 75$?
I needed a spare key so I went out and found the site at that time. And I think they even offered theirr service on eBay.
Thanks for the suggestions. I'll try some of these to work out the issue.
I had another issue that I don't think is related. The transmitter unlocks and locks the passenger door as it should but does not unlock or lock the drivers door. I do hear clicking at the driver's door latch. I removed the door panel and the mechanism is hard to access. The hard key unlocks and locks the door as it should. Any ideas?
Thanks
Dennis
Thanks
Dennis
What I've noticed is the driver's side actuator appears to be trying to move the lock button, but isn't quite strong enough to do so. You can see a little wiggle to the button when the noise is triggered. So, I'm thinking it's an issue with a tired lock actuator. I had to replace the window actuator at the same time, which made the lock assembly significantly easier to get to. I'm not looking forward to doing that again with the window rail still in place.
I found a possible solution:
https://www.clublexus.com/forums/sc-...ml#post2492391
I'll give that a try as soon as I hook the power back up. I looked at the old lock actuator and it's definitely a threaded end cap that the white clip on the lock cable goes over, so there could well be something to that.
Edit: Tried it out and no luck, even though the barrels on the good and bad doors were previously adjusted a couple threads differently.
I had this problem when I first got the car (got a 92 like 3 years ago) it was a problem with the tension in the wire, fixed it by adjusting the plastic piece near the end of the wire. If I remember correctly turning one way tightens it and other loosens it.
edit: (I should explain, it's the tension between the plastic piece and the 3 inches away where it connects to interior door lock. If it's too loose it doesn't move anything I think)
Thanks
Dennis
Thanks
Dennis
TYPE B
So now I have a master key that works in the ignition and doors, starts the car and all three buttons on the remote work. It still does not work in the trunk, glove box, and trunk lever release. The sides of the key do have a raised edge unlike the valet key that has a flat edge.
At least I'm getting closer.
Thanks,
Dennis
