SC- 1st Gen (1992-2000)
RPF1 owners
Old 09-09-16, 08:15 AM
Ali SC3
Ali SC3's Avatar
Originally Posted by t2d2
I've got a set of Supra TT's with 225 winter tires, and that's stretch city in the back. They're smiling at the thought of an extra 70mm.
I would say it's 50/50. Side shots and a lot of the angled shots make it look like they fit within the fender, because the tire being inside the vertical line makes it deceptive. It takes an almost straight on shot to see that the rim is jutting out. Then, of course, there's all the posts saying something fits but not having accompanying photos.
Well supra TT wheels work great with 275 out back and 245 up front and I use those all season. 225 for winter actually works cause in the snow you do want skinnier tires.
Aftermarket wheels which are 10+" wide I would get an offset that could stuff a 295 under there at the very least but I like having more tire.
Gerrb was trying to get me to stuff a 305+ in there when I was shopping around, that would have been meaty!
Different SC owners have different goals, some want max tire some want hella flush camber'd n stretched, I like both looks personally but I always go for less aggressive offset and max tire.
Its weird that places like ebay and whatnot have these wide 15mm offset wheels listed for the SC as fitting, and really they don't fit at all with a big tire unless you do a lot of work even then its questionable. I would grab some in proper supra fitment and then you can usually run a normal/big tire.
Old 09-09-16, 08:29 AM
t2d2
t2d2's Avatar
I'm not putting enough power to the pavement for that to be a primary concern, but I did briefly entertain making the TT's my summer wheels for that reason.
Old 09-09-16, 09:08 AM
nnnickkk
nnnickkk's Avatar
Im planning to go 18x9.5 +27 & 18x10.5 +30, prob 245/40 and 275 or 285 35 in the rear. A little less aggressive offset then the RPF1 so should be ok...I hope.
Old 09-09-16, 09:57 AM
Blkexcoupe
Blkexcoupe's Avatar
I would say go with a 275/35/18. The 285 can fit, but it'll poke out too much in the rear and kick up a lot of dirt on to the rear quarter panel which doesn't look as nice on white paint. Plus a 285 will be more square on the rear giving you less clearance if you want to ride low.
This is the only photo I could find showing fitment with these wheels. This should give you a good idea of how your wheels will fit with a 275 in the rear. Ignore all the tape and electrical wiring, I was in the middle of polishing.
Old 09-09-16, 09:58 AM
Ali SC3
Ali SC3's Avatar
It handles better even if you don't have the power yet, well at least I think it does... and you don't need power to yank the e-brake =)
Old 09-10-16, 08:08 PM
Duck05
Duck05's Avatar
The wheel offset thread I found to be very informative and full of many options to pursue.
In doing all of the reading and research, one opinion I came away with was the width of the wheels does not have to be that radical unless you want to have a lot of stretch (which I did not) and have to resort to fender mods (that I did not want to do or see the benefits) or camber settings that would effect tire wear and maybe even safety.....
Once I decided on wheel size and whether I was up for a staggered setup, the decision was 8 inch width on the front and 9 for the back. The wheels I selected, though, did not have 9 so had to go with 9.5 which then allowed for 235F and 275R as final choices... Of course, the offsets for each wheel had to be taken into account and in going with the TSW-Lumarai line being designed to fit Lexus we achieved the fit, stance, and look desired.
The RPF1's come in many sizes and offset on the 18 inch models so hope you can select ones that do not require a lot of fender work, spacers, or radical camber to get your target look.....
Old 09-12-16, 06:12 AM
flexnix
flexnix's Avatar
Seems I might be leaning toward
18x9.5 +15 all around with 245/40/18. With just rolled fenders you think they'll fit just fine?
This is the same setup. You guys think it would rub?
Old 09-12-16, 07:35 AM
LEXXIUM
LEXXIUM's Avatar
18x8 +35F 235/40/18 18x9.5 +35 265/35/18 rear no spacers
Old 09-12-16, 07:37 AM
LEXXIUM
LEXXIUM's Avatar
One more, and I love the wheels too
Old 09-12-16, 08:09 AM
t2d2
t2d2's Avatar
Only if you want camber/stretch. By my rough math, the rims will stick out a little over 1" in front.
Old 09-12-16, 08:25 AM
flexnix
flexnix's Avatar
So I guess he's cambering the front to compensate for that 1" right? I guess now that I look at the photos it seems like that's the case. On our cars for camber adjustments could be done with or without coilovers right? Sorry, I'm new to the SC platform.
Old 09-12-16, 08:38 AM
t2d2
t2d2's Avatar
Keep it simple and follow the numbers I posted previously, and which have been echoed by a few others in the thread. 17x8 +30 is about as flush as you can get up front. Anything wider or lower offset will push it out from there and will require more than fender rolling to fit. Stretched tires will give it the appearance of fitting in many photos, even if it sticks out quite a bit.
Old 09-12-16, 08:42 AM
flexnix
flexnix's Avatar
Love the offset! They line right up.
Old 09-12-16, 08:44 AM
flexnix
flexnix's Avatar
I've been wanting to go 17's because I would like meater tires, and less stretch. Look at this Lonnie's from the Supra Store.
Old 09-12-16, 02:45 PM
Blkexcoupe
Blkexcoupe's Avatar
Since you sent me a PM for the specs, I'll just post them here to clarify for anyone else looking at this thread.
Black SC300 (rough estimates on camber because things change often on this car and the picture is from 2011 or 2012)
18x9.5 +27 245/40/18 Around -1.4 to -1.6 degrees of camber
18x10.5 +30 275/35/18 -1.6 to -1.8 degrees of camber
White SC300
18x9.5 +22 245/40/18 -2 degrees of camber
18x11 +30 275/40/18 -3 degrees of camber
Quick Reply: RPF1 owners
