Jzs147 lsd in a soarer
Found a jzs147 diff locally for sale.
Anyone one know if this diff will fit a soarer/sc?
Searched online and theirs different info. Saying only the jzs161 diff will fit the soarer/sc. While others say the jzs147 it will fit.
Read the link you posted already. One guy says it fits other guy says it doesn't.
Wonder if you can take out the LSD unit and swap to your differential
https://www.clublexus.com/forums/1ge...ferential.html
I have firsthand experience with this so I can tell you what the deal is. The lsd out of a jzs147 2jzgte aristo does fit the soarer/sc HOWEVER: the 3 bolt flange of the aristo diff was larger and therefore does not bolt up to the driveshaft in the soarer/sc. this flange can be swapped over though.
Read some posts on soarerworld and driftworks.
And you sir have the same answer.
Our flanges are 101mm and the 147 flange is 111mm
Thanks alot.
Thanks alot.
