I hate each and every single one of you...
Super Moderator
Irving - if you are eventually boosting your car ... I would suggest go with a bumper with the upper grille . The front opening of the SC bumper is small . With a thick inter-cooler , an AC Condenser and a thick Radiator .. that opening will help the cooling system a lot when you crank up that boost .
Welcome, Irving!!! Glad you caught the "disease" like the rest of us. At least you have access to one of the best body kits for our cars.... LOL.
Hope to get my front end installed this week or next.
The slot was added in 97 due to the fact that they had a tendency to over heat in warmer climates in traffic, I live in a cooler climate plus have a new 2 core rad in car. I will at a later date when I'm ready to purchase a body kit contact you for info on the pre 97 kits!you have available. I've had another kit in mind, but it ships from Japan. Your kits seem to come highly recommended from the guys on here. I also have no plans to boost my 1uz.
I thought the '97+ front bumper slot was cosmetic only? Wasn't it reported recently that it's not actually a cutout? And even if it did go through, the part behind it that directs air from the grill up to the radiator would need to be modified with an additional channel for the slot. Was it?
Super Moderator
Irving - since you are a vendor on this forum , can you look into the probability or possibility of doing the following in poly-urethane ? You probably can do a group buy to gauge interest and will be your condition to go ahead with the manufacturing just like you did with the Aero Craft Body Kit.
a) an ENGINE TRAY that bolts from the front bumper all the way to the firewall .... can be one piece or two three, four or five piece which ever is best .
Purpose :
1)Protect the engine from dirt .
2)Minimize messing up garage or pavement from fluid leaks if that part directly under the engine is kinda like a bowl .
3) Designing it with louvers just below the front bumper and directed upwards would turn air towards the coolers ( IC , condenser , radiator) and engine . That will definitely help a lot in cooling the system.
b) a REAR DIFFUSER ...one that can have single or double exhaust opening just like your rear bumpers.
something like this will be dope .... should not only be aesthetically nice , the design should also be functional (improving air flow under the car and reducing turbulence and drag)
Purpose :
Purpose :
Purpose :
+1 for the under engine tray. Great suggestion Gerry
Super Moderator
Just make all your SC product designs simple but nice and functional . They should not make our SCs which are suppose to be luxury cars look like they had been bastardized . Any changes done in an SC should for me be an improvement either of the function without sacrificing the looks or the looks itself. That is the only way we can have hope in keeping the values of our SCs . The more they are bastardized ... the more their values go down the gutter .
