SC- 1st Gen (1992-2000)
Sc300 Motor Shut Down
Old 04-08-16, 10:41 AM
flosssc
flosssc's Avatar
Default Sc300 Motor Shut Down
Need your help again CL!
So a few months back, my ecu took a crap and did the normal white smoke, rough idle, and motor shut down. So i sent it off to Tannin to have them fix it. They sent it back and the white smoke issue was resolved. The idle is still a little odd and the motor still shuts down due to idle not holding up. So i plugged up a JDM aristo ecu and none of the problems are there, except the acceleration is rough. Let me know what you guys think it may be, and the link to it is below. I was on the gas to keep it up during the beginning.
https://www.youtube.com/watch?v=oyWp...ature=youtu.be
Old 04-08-16, 11:32 AM
flosssc
flosssc's Avatar
Is there someone with a 92-94 sc300 in austin texas that's willing to let me test the ecu on their car?
Old 04-09-16, 01:23 PM
BiGEZ
BiGEZ's Avatar
Sounds like you are still having issues with the ECU, as you plan try to switch it out with a know working an see. When last you did a tune up, de carbonized the intake system and check your timing? That could be the cause of your low idle issue.
Old 04-10-16, 07:51 AM
Rickbean
Rickbean's Avatar
open up your ecu and see if you have any leaking capcitors..send to drift-motion for rebuild...profit
Davon94
03-05-18 08:01 AM
xAntwann
Performance & Maintenance
02-15-16 06:07 PM
lex1220
24
08-23-11 09:45 PM
Rising_Sun
05-01-09 01:32 PM
LocknRoll
04-09-06 09:07 AM
Quick Reply: Sc300 Motor Shut Down
