92 SC 400, Temp gauge "HOT", w/ check eng. light
I am stumped. My 92 SC400 started having the temperature gauge climb to hot but then return to normal. Today the gauge went to hot with my daughter driving, then the check engine, then the overflow tank cracked at the cap.
I think it is a thermostat, maybe the water pump. BUT the odd thing is that the cabin air is not getting hot, at all, meaning no coolant is getting to the heat exchanger. Where would you start?
Thanks for any suggestions you may have.
