i need help finding a part for my lex sc400 98
Old 11-28-15, 06:25 AM
sc400730
sc400730's Avatar
Default i need help finding a part for my lex sc400 98
This is part of cooling system t stat housing is attached to it along with upper radiator hose broken off with two long bolts snapping in place it reveals two coolant ports one square and one circle in shape I'm stumped on this I really need to figure this part out to move on in my collision repair all body work I's done radiator support and radiator were pushed in far enough not to damage any pullys or belt even stayed intak just cracked that peice now is I possible to weld part together or jb weld or some kind of adhesive witch is able to withstand the heat and pressure.... Please and thank you. I really need the answer to my question
the pic ..... its the piece right under the throttle right next to the radiator house (top) its connected to the thermostat housing.... please anyone can you help naming this part??????
Old 11-28-15, 07:18 AM
pogoism9
pogoism9's Avatar
16032-50070 is the housing that the thermostat goes in. Runs about 90 new.
16355-50070 is the water joint assy that the housing sits on (aside from the water pump). This is where your top radiator hose attaches. Also runs 90 new.
If used is your game, ask Aliga in the classified section, he may have one
Old 11-30-15, 08:58 PM
sc400730
sc400730's Avatar
here is a pic so we can confirm that is the same part we are talking about
Old 11-30-15, 09:05 PM
sc400730
sc400730's Avatar
Default here is pic i think
I don't know how to get the pic to show let me know if you can see the image
Old 11-30-15, 10:05 PM
pogoism9
pogoism9's Avatar
Can't see it
bigbody305
ES - 5th Gen (2007-2012)
13
11-28-11 06:57 AM
94sc400GRN
08-19-08 09:26 AM
lspecz
10-04-07 12:55 PM
Quick Reply: i need help finding a part for my lex sc400 98
