Choice between two used cars - Please Help
#31
That Red one at Koons is very nice and looks very clean. Basically it is a 15 year old car with two years worth if miles. I am sure in 2003 a Lexus SC300 with 25,600 miles would have sold for way more than $15K, but that seems like a very high price.
In April I did purchase this one owner 1997 Lexus SC300 with 83K miles for $7,200. Before going to look at the car they replaced the brakes and rotors. As part of the deal I had them do a complete timing belt with seals and water pump. These engines do need to have the timing belt serviced at 90K and that can easily cost ~$1,500.
But you are correct, these are great driving and handling cars.
Good Luck with your search.
#32
Find the car
I found the car using a saved Craigslist Search using Google.
I live in Raleigh, NC and I searched the other local NC Craigslists. This car was located in Wilmington, NC, about 120 miles away. I was alone one weekend and decided to drive down and take a look. It was at a small dealership that sold mostly high-end cars that were 3-10 years old with lower mileage. This was the lowest priced car they had on their lot. I took my tools intending to give the car a though examination. When I showed up they gave me the keys and called the shop about 5 miles away that does their service work. They said I could take it down there and they would put it on a lift for me to check out. When I got to the shop, they presented me with the report they created when the car was brought into them. It listed that the brakes NEEDED to be done (so that was done at that time), and the following was recommend.
I went back and offered $7,000 cash with the car dealer having that repair shop do the complete timing belt. They countered $7,500. I said that was too high with it needing tires and transmission pan dropped, and started to leave. The guy said he could do $7,200 with the timing belt.
Since bringing it home, the local tire shop installed new Hankook Ventus S1 Noble 2 Tires, and I dropped the transmission pan and installed the new gasket on the pan. (No more leak) Last weekend I replaced the Spark Plugs and Wires, not a hard job but more involved than any other car I have ever worked on.
A couple weeks ago I drove it from Raleigh to DC and back for a long weekend. It drives like a dream.
More Pictures:
- Complete Timing Belt (Due at 90K)
- Small Leak at Transmission Pan
- Tune-up - New Spark plugs and Wires
- Tires - Had plenty of tread, but were dry rotting due to age.
DEAL
More Pictures:
#33
If you can document the mileage and service, low mileage "garage queen" can be a great find. That said, an SC that has been driven, well cared for, and garaged can be the best value . . .I bought my current (2nd) SC400 from an elderly gent in Dallas back in 2009. It's a 1997 black on black leather, and had 66K miles at the time. Beautiful car, chromed BBS rims, flawless original leather. He had service records, the car had been garaged, and though the miles were low, it has been driven regularly. I bought for $12K, drove it home to CA. Since then, I've spent about $6,000 in maintenance, and another $2,000 in minor mods over past 6 years, and just turned 140K miles. People still stop me in parking lots and ask about the car, and I do think the market is beginning to rise for unmolested, exceptional cars. I know I wouldn't sell mine for less than $8K, and I'd probably be stupid to do that. Shop carefully, get the best car you can find/afford, take care of it and you can drive it a long, long time. Good luck
#35
#36
#37
Fd,
I would want an independent inspection done before anything else. Low-mileage doesn't mean that rubber hoses, belts, and tires, don't decay, they do. A timing belt, for example, should be replaced around 100,000 miles OR seven years or so, depending upon climate. Tires shouldn't be driven after five to seven years from date of manufacture. An independent inspection may turn up a nasty surprise or two, or nothing at all. That's what you need to know before making an offer.
#39
yes, the black on black was at the dealership and they said they would fix everything before purchase. But since I don't know anything about cars, they could tell me anything and I really don't know if it was fixed. The vibrating gas pedal turned me off from that vehicle.I know its rare but there was cosmetic things that doesn't show up on the pictures.
I found another one close to me black with tan interior ( I know...), The CARFAX report looks great...
http://www.carfax.com/VehicleHistory...&partner=CDM_0
if I can get them to do the timing belt for me, it may be a go. I will test drive it next week.
#40
Fd,
sound and solid advice. Thanks!
#41
Go Look at That Black and Tan
Looking at the Car Fax it appears that most likely the timing belt and water pump was done on 12/16/2008 at 77,546.
It lists the following work:
Recommended maintenance performed
Rear differential fluid flushed/changed
Transmission serviced
Battery serviced
Tire(s) balanced
Safety inspection completed
Water pump replaced
Drive belt(s) replaced
Air filter replaced
Brake fluid flushed/changed
Then on 9/26/2013 with 90,138 miles they did this work:Rear differential fluid flushed/changed
Battery serviced
Tire(s) balanced
Water pump replaced
Air filter replaced
Maintenance inspection completed
Four wheel alignment performed
Washed/detailed
Oil and filter changed
Four tires mounted and balanced
Differential fluid flushed/changed
Spark plug(s) replaced
This car was well taken care of and always service at Lindsay Lexus of Alexandria. I would make a call to their service department to confirm the Drive Belts included the Timing Belt, but with the water pump replaced, I think there is a high probability. In today's cars changing the spark plugs is all there really is to doing a tuneup, and the brakes fluid was flushed in 2008 and again in 2012, it should be done every 3-4 years, but I have seen many cars that it has never been done. Four wheel alignment performed
Washed/detailed
I would still try to get the car inspected by an independent car shop. I put together the attached document for inspecting a Lexus SC300 that you might find helpful.
#42
That one looks very nice.
Battery serviced
Tire(s) balanced
Water pump replaced
Air filter replaced
Battery serviced
Tire(s) balanced
Water pump replaced
Air filter replaced
Washed/detailed
Washed/detailed
oh wow, you know what, you are right! The timing belt was replaced!
from Lexus report:
WATER PUMP PLEASE REPLACE WATER PUMP, TIMING BELT AND DRIVE BELTS -SERVICE COMPLETED
My mechanic is in DC. But if anyone has an expert SC mechanic in DMV area, please let me know. I can take the car there, if not, I will just use my mechanic.
#44
#45
120K Sc's are young adults with long lives ahead of them. The good thing is, they outlast most motors and trannys AND those parts are really cheap if they ever fail.
You can get great 1UZ or 2JZ for less than $500 all the time.
Don't worry, just have a really good, SC knowledgable mechanic go over it well.
man o man
that SC drives like butter!!!!! It was so smooth, I fell instantly in love.
That particular car did have problems such as a vibration coming from the gas pedal. It was a weird sensation since I never felt that before. The gas was on E so I don't know why it happened. The passenger door lock was having trouble too, couldn't open from outside... scratches and a loud grinding noise coming from the back. I was told it was the antenna going up and down. It was loud and unpleasant.
But the ride, it was nice!!! I'm now going to search harder for something I can buy at a reasonable price.
2. Door handle - This is usually caused by a plastic clip breaking on the door handle. It's an easy $3 fix if no one has rolled down the window since it broke. Once the clip breaks the rod it was attached to gets in the way of the window, so if someone rolled down the window it bends the rod and it never works the same after.
3. Rear noise - If it was the antenna it would only make noise when the radio is turned on and off (when the antenna is supposed to move). If there is always a noise I would think the rear brakes need to be changed.
