SC- 1st Gen (1992-2000)
new to this wanting suggestions...
Old 05-14-15, 12:32 PM
lochone112
lochone112's Avatar
Default new to this wanting suggestions...
Well im knda Lexus da new to this but my friend talked me into buying a 1999 Lexus SC300... anyways im looking to swap to a manual by the end of the year was just curious what the best transmission to go with is and what clutch and parts to that etc? it has the stock 2JZ engine in it.
Old 05-14-15, 01:53 PM
CatManD3W
CatManD3W's Avatar
If price is not an issue then go v160 or r154 if you plan to boost it later...if not then the W58 will work fine
Old 05-15-15, 06:01 AM
Studiogeek
Studiogeek's Avatar
Nissan CD009 swap is the "new kid on the block". Many LOVE this swap. I am considering it as well.
Old 05-19-15, 08:34 AM
lochone112
lochone112's Avatar
would i need an adapter plate with this transmission?
Old 05-19-15, 12:27 PM
Ali SC3
Ali SC3's Avatar
there is a 30+ page thread that people are working all that stuff out in the performance section. yes you need an adapter plate. start reading there lots of info.
Old 05-19-15, 06:19 PM
pogoism9
pogoism9's Avatar
I have it on good authority that you can find a full set of parts that will just bolt right in to a 300 and work as if Lexus designed them for the car...
Old 05-19-15, 07:50 PM
LEXOWINO
LEXOWINO's Avatar
Yes?
Could you tell us about it?
Old 05-19-15, 09:08 PM
Studiogeek
Studiogeek's Avatar
Originally Posted by LEXOWINO
Yes?
It is a great option for high HP cars. Cheaper than the V160 and similarly priced to the R154. Stronger than the W58 and R154. Holds over 1000hp and is 6 speed. Needs kit with adapter plate, clutch and more. Only logical for high hp applications in my opinion.
My car is being NA/T right now. Ill keep it low boost until I replace the W58 with the CD tranny. On that day, I can turn up boost and have some read fun!
Old 09-12-16, 12:49 PM
lochone112
lochone112's Avatar
well the time has come... only I got new questions now... I ended up getting a 91 lexus with the stock w58 manual 5 speed in it. was talking to my buddy and he said the engine is also ideal due to there being no VVT... so im curious... would the reward outweigh the risk in just swapping engine and trans? and would I just be able to swap the ECU... Wiring....and trans, or would it be too much of a headache.. Also is there a step by step guide on how to swap from auto to manual....searched on here couldn't find anything any and all advice is much appreciated. Thanks!
Old 09-12-16, 02:29 PM
LoveSCs
LoveSCs's Avatar
check my build thread for step by step in swapping cd009 trans in:
https://www.clublexus.com/forums/bui...1jz-sc400.html
As far as swapping engine out with trans, it depends which way you want to go. You could just go NA-T, or you could by an aristo 2jzgte and swap that in. It depends which way you want to go and the health of the motor that's currently in your car
Old 09-12-16, 05:46 PM
lochone112
lochone112's Avatar
Well later down the road I am looking to add a turbo... so that's the route I'm looking to take and as far as the health both are in pretty good shape. I just was curious is I could swap everything being that the ecu.. engine trans and harness and be good as far as that goes
Old 09-12-16, 05:53 PM
mikef
mikef's Avatar
well hes asking for the best so the easiest is to just get a 2jzgte v160 swap and its all plug and play but if hes willing to cut and drill to get things to fit with a load more work then a cd009 is the next best option. but be aware, supra parts are very expensive
Studiogeek
SC400 / 300 Classifieds
10-22-15 06:24 AM
EvanBlank
14
04-18-14 08:28 PM
Cebo
Performance & Maintenance
11-09-12 08:23 AM
sc101
05-02-11 09:03 PM
Quick Reply: new to this wanting suggestions...
