SC- 1st Gen (1992-2000)
Brake Booster/ Brake Master Cylinder YEAR and MODEL interchangeable?
Old 09-22-14, 07:02 PM
mak89
mak89's Avatar
Default Brake Booster/ Brake Master Cylinder YEAR and MODEL interchangeable?
Unfortunately my brake booster went bad now I'm looking to replace it along with non-trac brake master cylinder. I'll be buying a used brake booster opposed to remanufactured or aftermarket but only could find used ones for 92-96 sc300/sc400.
Does anyone know if earlier model year (92-96) brake boosters can be used with later sc300/sc400??
From what I've researched the main difference is that pre 1999 brake boosters have 3 bolts for the brake master cylinder instead of two, which I don't mind since I'll be replacing that as well.
symptoms: stiff brake pedal, vacuum hiss sound coming from pedal area, still can brake with A LOT of pressure applied. All hoses connected, brake fluid level fine, check valve works properly.
Appreciate any input
nobelnabil
09-21-18 12:09 PM
stnick007
Suspension and Brakes
03-02-18 06:03 PM
AlDavison
11-28-17 04:48 PM
CreativeS
12
11-18-16 06:28 AM
Lexus082
15
10-17-07 03:39 PM
Quick Reply: Brake Booster/ Brake Master Cylinder YEAR and MODEL interchangeable?
