1JZGTE Tach Fix 92-94 & 95-96
Old 07-21-14, 03:09 PM
SC2JZ300
SC2JZ300's Avatar
Default 1JZGTE Tach Fix 92-94 & 95-96
While swapping in a different gauge cluster from a 95 into a 92 chassis research was required to make sure it was a direct swap. After consulting w/ many old threads and on multiple forums, it was founded that it is a direct swap without issues. SC300 to SC300 Chassis.
Upon installation of the 95 cluster, the RPM's were founded to not be working.
Further research was needed as my chassis was 1JZGTE equipped.
After deeper research 7+years back there were some threads that stated a resistor could be jumped to input a tach signal. Below with pictures will help guide with the install.
Tools:
Soldering Iron or Gun
Safety Glasses
1" of Wiring Stripped On Both Ends
1. Removing Gauge Cluster is Required For This Mod: PULL YOUR NEGATIVE TERMINAL BEFORE REMOVING GAUGE CLUSTER!
2. Removed the 4 Phillips Screw Holding The Back Housing
3. For the 92-94 SC300 Gauge Cluster You Will Need to Solder in A Wire To Jump the R109 resistor, This is located At the Top of The Arc Of The Cluster (This was done by the previous owner w/ alot of Excess Wiring)
4. Moving On To The 95-96 Cluster You Can View Where The Wiring Was Soldered In. This Resistor Is R73, located also at the Top Of The Arc Of The Cluster.
5. Reverse The Procedure and Enjoy Your Working Tach w/ 1JZGTE
Old 07-21-14, 04:40 PM
BiGEZ
BiGEZ's Avatar
Good job Henry, I am glad you got the the cluster to work.
Old 07-21-14, 08:29 PM
SC3NAT
SC3NAT's Avatar
Thank you. Looks simple. Im getting my gauge cluster back from Tanin Electronix...they fixed the speedo and redid all the lighting but all it needs now is this mod for my 1J when it goes in. :-D
Old 07-22-14, 12:09 PM
SC2JZ300
SC2JZ300's Avatar
Thanks Eldon, the hardest part was doing the hour worth of research to confirm which resistor. Soldering in the wire took 5 Mins including disassembling.
Old 07-22-14, 12:34 PM
Kris9884
Kris9884's Avatar
Is this the same procedure for the Soarer digital tach?
Old 07-30-14, 03:42 PM
SC2JZ300
SC2JZ300's Avatar
Nah man not even close, soarer requires even more work than the 97+ cluster.
Good Luck Though!
Old 10-09-16, 05:53 PM
tjmhillz
tjmhillz's Avatar
bumping this up.. What gauge wire was used? i recently did a 1j swap and stupid tach doesnt work.
Old 10-10-16, 05:22 PM
roc
roc's Avatar
I this the same procedure on
the 2jzgte swap
Old 10-12-16, 06:28 AM
kez
kez's Avatar
tj I used stranded 14 gauge wire
Old 10-14-16, 07:06 AM
tjmhillz
tjmhillz's Avatar
Ok cool thanks bro.
Old 10-16-16, 06:30 PM
roc
roc's Avatar
Does this work on the 2jzgte swap too
Old 12-20-16, 06:51 PM
tjmhillz
tjmhillz's Avatar
which resistor did you end up using? thats where im at now trying to figure out the right resistor to use. my fear is i use the wrong one and blow something up lol.
Marckussb
SC- 1st Gen (1992-2000)
03-11-14 04:41 PM
Devor
08-28-11 09:24 PM
Superjatt
CL of Southern California
02-08-11 05:50 PM
shaodome
08-06-10 07:10 AM
VJZ
10-08-08 02:16 PM
Quick Reply: 1JZGTE Tach Fix 92-94 & 95-96
