SC- 1st Gen (1992-2000)
Can anyone help me removing the car lighter?
Old 06-06-14, 12:23 PM
Nexevious
Nexevious's Avatar
Default Can anyone help me removing the car lighter?
I want to replace my car lighter. I already have a replacement, just need help with pictures on what to do after I remove the console. Any help would be appreciated!
Old 06-06-14, 12:24 PM
t2d2
t2d2's Avatar
Are you looking to replace the whole ashtray or just the cig lighter? I never did figure out what holds the lighter in. It seems to have little snap rings of some sort, and no obvious way to disassemble.
Old 06-06-14, 12:27 PM
mecheng10
mecheng10's Avatar
more than likely you will have to pry it out...
there is some type of tension force on it.
Nexevious
Nexevious's Avatar
Not the ashtray, just the lighter well.
Here is what I got so far:
Old 06-06-14, 12:31 PM
962jzsc415
962jzsc415's Avatar
Remove the whole center console. Turn around to expose lighter component....There is a piece on the component you can twist to unscrew off. Then the lighter will be able to be removed
Old 06-06-14, 12:33 PM
Dream36
Dream36's Avatar
Ok, to remove it pull the center trim, you have to remove shifter first then shifter surround which has three plugs. The center trim has two plugs on top left as well. Once you get those two pieces out if the way you need to remove radio/hvac/ashtray assembly. Once removed there is a blue plug to the lighter, remove that. Once you have the ashtray upside down you will see a crimped looking ring around te lighter. You need channel locks to twist it off (lefty loosey) when you start twisting it will shatter and crack a clear/white plastic trim. Ignore this piece as it is brittle. Once you have it off you can install your start button or cig lighter of choice.
Hope that helps it really is simple. Only issue you may have is the cig lighter spinning while trying to remove clamp (the crimped looking ring)
Old 06-06-14, 01:38 PM
Nexevious
Nexevious's Avatar
Alright so I got the ashtray out instead, so that I could go back inside, cuse it is so hot outside.
I need to know what to do next because it seems like it has 2 different parts to it.
How do I take it out?
Old 06-06-14, 01:40 PM
Nexevious
Nexevious's Avatar
(I apologize if the images are so big)
Old 06-06-14, 01:41 PM
Nexevious
Nexevious's Avatar
The new parts:
Old 06-06-14, 01:51 PM
Dream36
Dream36's Avatar
Read my post above please. You may feel slow when you find out. The round part twists off, it connects everything together. Te square part is the light.
Old 06-06-14, 03:50 PM
Nexevious
Nexevious's Avatar
Ahh... I tell you plugging in my phone with that satificationary ding that it is charging felt soooo good. Took longer than expected, I had a new part that didn't fit, so I had to bend a part to hold it together, but thanks to everyone that posted, it really helped out!
/thread
Old 06-06-14, 04:18 PM
t2d2
t2d2's Avatar
That's way easier than I was expecting. The crimped lock ring is the key, and it loosens easily with channel locks. Just make sure to disconnect the white plug on the back of the lighter so you can pull the front piece out.
My white plastic trim ring on the front was already 1/3 broken, and those little pieces made me think that was the lock ring that had to be loosened somehow. No wonder I was confused. Now I can put my never-used lighter from the broken-hinged ashtray in the good ashtray with the gunked up lighter...
Old 06-06-14, 07:32 PM
jennie
jennie's Avatar
Stop posting wrong information.
I added a lighter to my armrest and referenced this thread to disassemble it.
Blueshark
ES - 5th Gen (2007-2012)
08-09-14 03:46 PM
tsxnbp
06-16-14 08:30 PM
TomsES330
06-05-10 01:59 PM
tskolak
07-10-07 02:02 PM
acc
07-06-07 09:21 AM
Quick Reply: Can anyone help me removing the car lighter?
