SC- 1st Gen (1992-2000)
First Visit To Drag Strip
Old 09-15-15, 10:32 AM
Halon
Halon's Avatar
Default First Visit To Drag Strip
Posted this in my project thread, but figured I'd post a new thread here for people who don't look at my project thread.
Sunday I got back from BIR in Brainerd, MN. Big weekend long event, was pretty fun. Been there before in my last project, but first time to the track in this car. Overall I think a very successful first track visit in this car. It wasn't perfect. I have a lot of learning to do when it comes to launching this car, my best 60' of the day was a 2.1. WIth my NT05R drag radials I think I should be able to get down to at least a 1.8 with practice.
My goal was really to just make some nice clean passes in the car. I was expecting 12's and 125 traps. I surpassed that with a best of 11.6 @ 131. If I can get that 2.1 down to say a 1.8 which I think is a very achievable goal, I'd be knocking on the door of 10's. And also getting the setup from it's current 20psi setting up to 30psi, I think my traps will be in the upper 130's. This will put it pretty much exactly where I had my old Talon at which was my end goal of this entire build. Similar power / track time as the Talon, but in a vehicle that is much more comfy / quiet / old man friendly / sleeper-ish.
Break down on how it went.
First "thing" that happened was we ****ed up the front lip taking it off the trailer. That was super sucky, but it sort of fell back in place fine so it's not so bad. Maybe I'll just get some carbon fiber band-aid stickers or something as a funny fix.
First pass was a 12.1 @ 127.5 with a 2.2 60'. This was in full street form (even still had the sub in the trunk). Car weighed in at 3460lbs. Launch was horrible, lots of wheel hop, NT05r's still at 30psi.
Second pass was an 11.6 @ 131.3 with a 2.1 60'. I removed a bunch of weight for this. Pass seat, sub/amp from trunk, all trunk carpet, rear seats all came out. Car weighed in at 3320lbs. This was my best pass of the day. Launch was a hair better, I had lowered the rear tires down to 20psi. The weight reduction had an awesome effect on the trap.
Third pass was an 11.7 @ 131.8 with a 2.2 60'. I removed the entire exhaust from the downpipe back. You can tell in the video it is significantly louder. It's stainless so I bet removing this put me under 3300lbs, unfortunately the scale was closed at that time so I didn't get to re-weigh it. I'd guess probably a good 40lbs was removed though, so probably right around 3280lbs would be my guess. I thought the reduction would have had a bigger impact on my trap, but I gained almost a mph with it. I put the tires down to 18psi. Lots of wheel hop again. Still was happy that I was able to basically duplicate the previous run. This was the end of Friday nights fun.
Fourth pass was the next day, Saturday afternoon. 2.4 60', but then you can see in the video this is where the car broke on the 3-4 shift. This ended my racing for the event, threw it on the trailer and called it quits.
I'm still not sure what exactly broke, but the symptoms are that the clutch basically no longer disengages the tranny from the motor. Everything feels right when you push the clutch. You can see the slave is pushing the fork just like it should. It just doesn't do anything. If you have the car in say 2nd gear and are driving around at 3k rpm, you should be able to push the clutch in and the tranny disengages, the rpm's drop to idle speed. My car right now, that same scenario you press the clutch in and the car just stays at 3krpm, the tranny is still engaged like you didn't press the clutch at all. But like I said above, clutch pedal feels normal. So the one thing that comes to my mind is perhaps the clutch fused to the flywheel? Or perhaps my master or slave is just on it's way out and not fully disengaging the clutch.
Car will put in the garage and stored for winter early. So I guess I'll get a head start on this winters upgrades, which now also includes figuring this issue out.
All in all though, I was really happy with the car.
Here's a video of the 4 passes in order taken from inside the car. Also a few pics I snapped.
https://www.youtube.com/watch?v=tcPb...ature=youtu.be
[youtube]tcPbRghQoQ0[/youtube]
Old 09-15-15, 10:47 AM
chnk
chnk's Avatar
nice, what power you putting down?
Old 09-15-15, 11:03 AM
SC2JZ300
SC2JZ300's Avatar
1992 SC300 E85 - BW 84-75, Megasquirt 3/3x, 2jzge, 350z 6spd Idle Vid, 561hp graph, 545hp Vid, Drivability Vid
Im interested in what happen to the trans at this power level, update on what happened is a must.
Old 09-15-15, 11:25 AM
Halon
Halon's Avatar
I don't think anything happened to the trans itself. I think it's either an issue with the clutch/flywheel, or perhaps just an issue with needing a beefier master cylinder. New Tilton master cylinder is on order, so we'll see if that is the lucky fix.
Old 09-16-15, 11:00 AM
smitty89
smitty89's Avatar
good times bro what size rear tire?
Old 09-16-15, 11:23 AM
ihiryu
ihiryu's Avatar
I'm assuming you have an early Z transmission, with external slave?
I'd say you killed the pressure plate. Maybe broke a teeth or two on it? But you should be able to remove the slave, and the dust cover and see in side of it. There's quite a bit of room.
Old 09-16-15, 03:27 PM
Halon
Halon's Avatar
It's the CD009 with external slave. If I broke a tooth on the PP I'd think I'd hear something. But who knows at this point. I do need to get it up on jack stands and see if I can see in there at all.
The rear tires are NT05R's 275/40/17
Old 09-17-15, 01:41 PM
olmytsi
olmytsi's Avatar
Hey,
Is this a built bottom end?
I am a fellow ex-dsmer...had a 98 Tsi Awd from 2003 to 2013 and an Evo 8 from 2013 to 2015.
Cheers,
T
Old 09-17-15, 02:53 PM
Halon
Halon's Avatar
I added head studs, but that's about it.
Old 09-17-15, 10:54 PM
Kris9884
Kris9884's Avatar
Isn't it funny how just a couple of bolt ons and a tune can get your car to similar numbers as GTR's and ZR1's? Great work man, it's come a loooong way!
Old 09-18-15, 05:53 AM
Halon
Halon's Avatar
Couple bolt ons? lolz, feels like it's been a lot more work than that!
Old 09-18-15, 03:13 PM
Reyke
Reyke's Avatar
Quick question, what gear, approx engine rpm are you trapping in, and what final drive do you have?
By the way your power levels and track numbers really put a smile on my face because that's where I'd like to be.
Old 09-18-15, 08:20 PM
Halon
Halon's Avatar
I finished in 4th gear, somewhere around 7-7.5k rpm, I wasn't watching.
I'm on a 3.26 rear end.
Old 09-21-15, 06:46 AM
marhain
marhain's Avatar
may have broken the release fork.
Old 09-21-15, 07:13 AM
Halon
Halon's Avatar
Had the wife help me a little last night, I'm starting to think it's just not fully releasing due to lack of enough throw. Which means this new master may in fact do the trick. Fingers crossed!
Quick Reply: First Visit To Drag Strip
