SC- 1st Gen (1992-2000)
The electric gremlins strike again
Old 02-19-14, 05:06 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Default The electric gremlins strike again
i'm having an issue with my highbeams and side markers.
similar to this thread, in fact identical except no 93 drl:
https://www.clublexus.com/forums/showthread.php?t=548644&styleid=13
I ordered the part but I can't seem to find a place to put it.
I assume this is due to the fact that there are no DRL on 93.
Can anyone help? Thanks.
Old 02-20-14, 09:09 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Bump, still hoping for answers from someone with some knowledge on the SC's systems
Old 02-22-14, 12:47 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Any help on this would be very appreciated - - still puzzled
Old 02-22-14, 11:49 PM
oldManTan
oldManTan's Avatar
so what exactly is wrong? your headlights don't work? did you check the fuses? the relay for the lights? what did you order?
Old 02-23-14, 04:48 AM
ArkLaTexSC
ArkLaTexSC's Avatar
Check the thread I linked, but basically, the brights usually don't work, the dash bit for them doesn't light up, and the side markers don't work. I've replaced fuses a lot.
Old 02-23-14, 07:41 AM
BenStoked
BenStoked's Avatar
are the fuses blowing, or are you just changing them?
have you tested the relays?
Old 02-23-14, 08:31 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Did this help you?
Old 02-23-14, 01:50 PM
ArkLaTexSC
ArkLaTexSC's Avatar
I changed them in case of an unusual break, they didn't blow.
Which relay(s) should I check?
Old 02-23-14, 01:52 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Originally Posted by 1JZPWRD
Did this help you?
I think I am pointed in the right direction now, so yes.
Old 02-23-14, 05:25 PM
BenStoked
BenStoked's Avatar
This is the big box under the hood.
Old 02-23-14, 05:31 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Thanks! I will take a look at these. The video was very helpful too. And if anyone wants drl relay #3 and will pay shipping, it's a $100 part free.
Old 02-28-14, 07:49 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Bought the two relays pointed out, and replaced. Brights work, as does the dash saying they do. Side markers are still out and I'll be hunting tonight for that one.
Old 02-28-14, 10:29 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Sure wouldn't have helped with mine. The wiring was trash. There was spliced in some wiring stretching to both markers and connected to what I can only assume was stuff from my non-existent corner lights. I cut all of the crap out, cut the wires down to the sockets and where it goes into the harness-ish-thing. After it started shorting when I attempted to wire it up again, I gave up and wired the markers in with the front signals.
FLAWLIS101
07-28-13 03:41 PM
XCRIS250
02-27-12 07:59 AM
VietScouty
GS - 1st Gen (1993-1997)
07-13-11 08:31 PM
stokdd
08-05-06 08:39 PM
Quick Reply: The electric gremlins strike again
