SC- 1st Gen (1992-2000)
Airbag light
Old 01-20-14, 11:49 AM
Sylexus
Sylexus's Avatar
Default Airbag light
When I bought my car, I noticed a little light on the dash, later to find out it is the airbag light. So I bought an IS300 Steering Wheel and Airbag along with the adapter so I wouldn't have to splice into the existing harness.
I just finished replacing it, come to find the light still on. Should I go ahead and find another airbag module and spring clock? I am trying to find out because my inspection is due in March so I need to get it done asap.
Thanks!
Old 01-20-14, 12:07 PM
Candela
Candela's Avatar
I have a similar problem. I've been told that it could be the airbag ECU that needs to be replaced. It's located underneath the radio. Not sure how or why those go bad, or if they actually do. Also check the front side impact sensors located behind each fender, I guess check if theyre missing or not plugged in? I've checked mine and theyre intact, but have not got around to looking at the airbag ECU.
P.S. Nice steering wheel!
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Did you try to reset it?
Old 01-20-14, 12:08 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Oh by the way the steering wheel looks very nice!
Old 01-20-14, 12:34 PM
Sylexus
Sylexus's Avatar
How do you reset it? Sorry my phone internet blows so I can't search atm. Thanks!
Old 01-20-14, 12:43 PM
Candela
Candela's Avatar
If the cruise control and I believe hazard button works, then the clockspring is alright IIRC
Old 01-20-14, 12:53 PM
Sylexus
Sylexus's Avatar
My Hazards do work, but my cruise does not! It didn't work with my old steering wheel.
Old 01-20-14, 01:15 PM
Joey-E
Joey-E's Avatar
Its probably been in a accident or the cluster was replaced. Try resetting it too see what happens.
GTX580
04-06-16 11:50 AM
little2576
03-28-15 06:51 AM
MongooseGA
04-13-09 11:55 PM
ktang235
04-15-08 04:28 PM
Quick Reply: Airbag light
