SC- 1st Gen (1992-2000)
headlight
Old 08-14-11, 05:20 PM
showgun82
showgun82's Avatar
Default headlight
can Someone help please, my head lights stay on when the car is off and the switch is off....had to pull the fuse just to take off the light . any one to fix this?
Old 08-14-11, 06:26 PM
CrazySC300
CrazySC300's Avatar
Does this happen when you shut the car off completely? I sorta randomly had this problem myself...It would turn off when I shut the car off completely...I'm thinking it's the ECU trying to relearn something...I'm not sure, Sorry I couldn't be of anymore help.
Old 08-14-11, 06:33 PM
blacksc4
blacksc4's Avatar
nvr heard that problem before, try unplugging ur battery for about 30 mins and put it back on and see if it changes
Old 08-15-11, 03:16 AM
showgun82
showgun82's Avatar
the light stay on when the car is completely off.....i did unplug the battery for 2hr and same issues....
Old 08-15-11, 04:00 AM
NerdRiot
NerdRiot's Avatar
Is your car lowered? If so, did you relocated your wiring harness?
Old 08-15-11, 04:02 AM
showgun82
showgun82's Avatar
not lowered...did not touch the wire harness
Old 08-15-11, 06:14 AM
xwingzero2
xwingzero2's Avatar
I'm with you on this one. I think its the ECU as well
Maybe the ECU's main relay is on with the key out of the ignition, so try wiring a switch in to cut power to the main relay.
Old 08-15-11, 10:49 AM
arbalist
arbalist's Avatar
does your dome light come on when you open the door and its set to "door".
ive seen this happen when the door switch is broken. The body's ecu gets confused and "thinks" you are still in the vehicle, so it doesnt set off the timer to deactivate the lights after x seconds.
Old 08-20-11, 12:32 PM
showgun82
showgun82's Avatar
the dome light is set to door and the light do come on when the door is open..and shut off when its close....
where is the main relay for the lights?
Old 10-19-13, 09:48 AM
zneubauer
zneubauer's Avatar
I got the same problem, wondering how to go about the possible door issue?
Old 10-19-13, 04:07 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Must be a Florida issue with the headlights.. LOL
2ndGen3
02-26-18 07:17 PM
TexasSC
07-13-14 02:37 PM
LEXUS714
04-08-12 09:50 PM
bowen.chau
RX - 1st Gen (1999-2003)
16
02-15-11 08:08 AM
TLW
Maintenance
03-30-06 08:35 AM
Quick Reply: headlight
