SC- 1st Gen (1992-2000)
Would you buy a late-model SC300(VVT-i) with high miles?
Old 06-18-13, 06:04 AM
jpvarghese
jpvarghese's Avatar
Default Would you buy a late-model SC300(VVT-i) with high miles?
Say, between 150k-200k miles, one owner maintained. What typically fails and needs replacing?
Old 06-18-13, 06:25 AM
06bluerex
06bluerex's Avatar
yes i would, actually i have a 99 with 280k miles.
its my daily driver, typical maintenance so far.
Old 06-18-13, 06:35 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Like there is a choice. The newest one is 12 years old.
Old 06-18-13, 06:36 AM
Maserati
Maserati's Avatar
Yeah same thing here, I Just got a 99 400 with 179k on the dash, but just do the maintenance and it'll be good, As long as the price isn't too high, its going to be solid if its been maintained.
Old 06-18-13, 06:58 AM
Luxor
Luxor's Avatar
YES i would
Old 06-18-13, 07:20 AM
Nojoi
Nojoi's Avatar
I would as long as I wasn't compromising quality for price. Like all things, it's what it's worth to you at the end of the day. As failures go, it is subjective to climate, storage and care. That said, I would do it if the color suited me.
Old 06-18-13, 08:50 AM
INTIMAZY
INTIMAZY's Avatar
240,000 miles here. They're old cars. They will break. Not any worse than average but it's reality.
Luckily, there is a massive community centered around this platform and all the sister platform mates so everything that can, will, or should break has been well documented and cheaper alternate fixes have been explored. Generally speaking, later models of a particular platform have had their kinks worked out and should be most promising long term. 200k miles on on the 2JZ is NOTHING. Seriously. There are people with 400k miles on original non-rebuilt motors.
Old 06-18-13, 09:18 AM
92SoCal
92SoCal's Avatar
Like everyone has stated, YES!
I love these engines.. they can last forever.. its especially good that its only been with one owner.. I mean as long as hes done.. even, an okay, job at tuning up his car you wont have to do much...
I got a 92' with 180k miles on it and have had to replace the following keep in mind it had 3 owners..
spark plugs
dist cap rotr
fuel pump and mod
fuel filter
clutch
clutch master cylinder and slave
AC compressor
So yes its extensive but i think worth it to know you have a reliable car
also for me i need to fix
Timing belt
water pump
power steering hose leak
pvc valve
control arm bushings
motor mounts
So basically everything you need to do make sure you ask what has been done already
Old 06-18-13, 12:03 PM
jpvarghese
jpvarghese's Avatar
Really? 2JZ? This isn't an urban legend or anything right? I've read about many high mileage stories of the 1UZ, but not much of the 2JZ since many become modded.
I'm looking at a few cars, '99-'00, all of them 1 owner with maintenance records, completely stock, no accidents, and in excellent condition. What's a amount to offer for the mileage range in the initial post?
Old 06-18-13, 12:06 PM
jpvarghese
jpvarghese's Avatar
Timing belt
water pump
pvc valve
motor mounts
What do you estimate all this to cost? Thanks for your response.
Old 06-18-13, 01:04 PM
Blkexcoupe
Blkexcoupe's Avatar
Pricing varies based on overall condition of the car and location. If the car still has nice paint and interior I would pay more for the car. I have a 98 SC300 with 165k miles very well maintained, clean paint, and clean interior (besides 1 tear in the driver seat) and I would ask for 7k in my area.
I've done most of these on my car. I bought the parts and did the labor myself.
Timing belt, water pump, tensioners, and all related parts - $500 in parts
Power steering hose was - $80 for parts and fluids
PCV valve - I haven't had to replace
Control arm bushings - about 500-600 for supra LCA arms (better to replace the bushings and ball joints at this age)
Motor mounts - I don't remember how much this costs.
Aside from the things listed above, the only other major issues I can think of are the rear main seal and vvti cam gear seal leaking oil. The vvti cam gear has to be replaced since toyota/lexus won't sell the seal by itself. The cam gear is a few hundred, and is basically the same as changing the timing belt, so I would do it at the same time if the seal is leaking oil.
Old 06-18-13, 01:37 PM
92SoCal
92SoCal's Avatar
500 in parts for this? i have found very good timing belt+ water pump kits for 280 and down?
Old 06-18-13, 02:08 PM
Blkexcoupe
Blkexcoupe's Avatar
280 for oem? I guess I should have broke down what was included in that 500:
Timing belt, timing belt tensioner, water pump, thermostat, thermostat gaskets, serpentine belt, serpentine belt tensioner, bolts, and fluids. (You probably don't have to buy new oem bolts)
Old 06-18-13, 02:12 PM
92SoCal
92SoCal's Avatar
ah okay yea nvm lol
Old 06-18-13, 05:18 PM
ASTERiSK
ASTERiSK's Avatar
Only if it was really clean and pretty cheap, the 98+ SC300's aren't something you can't turn the older SC's into. Only SC's anybody wants is a clean manual SC300 or 98 SC400, considering it's bone stock.
Quick Reply: Would you buy a late-model SC300(VVT-i) with high miles?
