SC- 1st Gen (1992-2000)
Do you have heat coming from your console? Here's why.
Old 10-25-12, 09:05 AM
gtsfire
gtsfire's Avatar
Default Do you have heat coming from your console? Here's why.
When you have your windows down or sunroof open do you feel your gear shifter get hot and feel heat coming from around the emergency brake?
Here's the culprit.
It's the rubber boot around the lower part of the shifter that's on the underside of the car. It is worn and has a gap in it allowing heat to be sucked up inside the car. The fix? Well that's up to you. You can order a new boot or find a fix yourself. If you replace the wole boot you'll have to remove the entire gear shift mechanism, which includes all this.
For now I just stuffed some insulation down around the lever. Did not completely solve the problem but is better for now until I can get the boot ordered and find the time to tear it all down again.
Old 10-25-12, 09:22 AM
durps
durps's Avatar
I noticed this tooo! I thought it was just me haha.
Since its getting cold out, I'll leave it as is so it can help and keep the cabin warm, but in spring I'll take a look at this.
Old 10-25-12, 10:06 AM
kez
kez's Avatar
This is the only bad thing of owning a sc in the summer if you live in area with warm climates.
I experienced it after 5speed swap test drive lol
Old 10-25-12, 10:08 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Yep, we've been discussing ways to fix this since CL launched in 1998 (2001 for the new site) since it has always been a complaint of SC owners. If you'd like some helpful hints on solutions just search around at what others have done.
Old 10-25-12, 10:51 AM
abounly
abounly's Avatar
Yup.
I cut the hole too big and heat was pouring in.
Old 10-25-12, 02:10 PM
gtsfire
gtsfire's Avatar
And if your auto shifter wiggles back and forth, replace the little bushings around the bolt the lever pivots on. The bushings are very very cheap and available from Lexus. You can replace those while replacing the boot. I have to check to see if the boot is available still.
steveis350
06-20-19 10:44 PM
BostonVP
12-24-12 12:11 PM
HTXSaint
08-20-11 10:28 PM
chex
11-18-10 06:22 PM
SMARK
05-11-03 04:12 PM
Quick Reply: Do you have heat coming from your console? Here's why.
