SC- 1st Gen (1992-2000)
How do you release seatbelt tension?
Old 09-19-12, 10:10 AM
Dx3
Dx3's Avatar
Default How do you release seatbelt tension?
Guys,
Replacing a worn drivers seatbelt because it has frayed a lot. I bought a used one and need to install it, but it's pulled in too tight for me to be able to bolt it in. Is there somewhere on it I can release tension to get some slack to install it?
Thanks,
Old 09-19-12, 11:15 AM
Dx3
Dx3's Avatar
As per our resident guru Gazi, if you put the seatbelt in the position it bolts up to, it will release the ball bearing and allow the seatbelt to pull out. This is a safety feature for if the car flips.
Thanks Gazi for explaining this
Old 09-19-12, 11:36 AM
daily400
daily400's Avatar
if that doesnt work hold it up right then slowy tilt it forward till 45 degrees and pull the belt down at the same time
decypher
06-25-15 03:17 PM
johnslee
47
06-23-14 06:05 PM
jtwags
04-08-14 08:19 AM
markpaco
Maintenance
07-06-02 07:38 PM
Quick Reply: How do you release seatbelt tension?
