SC- 1st Gen (1992-2000)
Both power mirrors dont work
Old 06-04-12, 12:03 PM
Farino81
Farino81's Avatar
Default Both power mirrors dont work
For some reason both of my power mirrors stopped working yesterday. They were working fine and then all the sudden stopped working. anybody know what i should check or what it could be?
Old 06-04-12, 12:08 PM
SEXC
SEXC's Avatar
Check the fuse first.
Old 06-04-12, 12:10 PM
Farino81
Farino81's Avatar
which fuse is it?
Old 06-04-12, 12:14 PM
Tabaka
Tabaka's Avatar
More than likely it's the mirror ECU. Aliga typically has them.
Old 06-04-12, 12:15 PM
Farino81
Farino81's Avatar
where is the mirror ecu located
Old 06-04-12, 01:39 PM
Tabaka
Tabaka's Avatar
It's a small ECU box located above the pedals and under the steering column. Get upside down on your floor mat and look up towards your steering column. You'll see a small ecu box located in this area.
Old 06-04-12, 02:40 PM
groverwood
groverwood's Avatar
I have the same issue. Is the ECU easily replaceable? How much $$?
Old 06-04-12, 04:27 PM
Farino81
Farino81's Avatar
can you someone post a picture of where the mirror ecu is located? i see a couple units but dont know which one it is..thanks
Old 06-04-12, 05:06 PM
Vortes
Vortes's Avatar
https://www.clublexus.com/forums/sc-...h-nothing.html
Seach before you make new threads, 99% of the problems you will face with your car have happened before and the answers are out there.
Old 06-04-12, 05:11 PM
Farino81
Farino81's Avatar
I did search and the thread you sent me has no pictures of where exactly its located
Old 06-04-12, 06:24 PM
Tabaka
Tabaka's Avatar
It looks like this
It should say part number: 89430-24020 right on the front. ...that's how you'll tell the part.
You can usually buy one used for $40. Create a WTB thread in the classifieds, purchase one, remove your old one, and install new one.
Old 06-06-12, 04:36 PM
Farino81
Farino81's Avatar
how am i supposed to get the upper bolt off of the ecu?
Old 06-06-12, 04:48 PM
- V -
- V -'s Avatar
i have the same issue, never have enough time to pull the damn thing out and replace it. O.L.T. posted a picture of the ECU's location a while ago but the picture disappeared from photobucket.Its above the pedals, easy to see but hard to get out. will take some tinkering.
Old 06-06-12, 05:03 PM
OG Dada
OG Dada's Avatar
This is what happens when you create too many threads of the same issue. I'll link you your other thread, where I linked a DIY I made, just for you. Post #5
https://www.clublexus.com/forums/sc-...irror-ecu.html
Old 06-06-12, 05:09 PM
CardosoA
CardosoA's Avatar
FUSE 100% if one didnt work understandable 2 fuse or wiring to panel.
Quick Reply: Both power mirrors dont work
