SC- 1st Gen (1992-2000)
100w bulbs in our cars a bad idea?
Old 02-26-12, 09:37 AM
Golden95SC
Golden95SC's Avatar
Default 100w bulbs in our cars a bad idea?
hey guys my bulbs just came in and i noticed that they are 100w low beam and high beams.
there not hids there just regular bulbs, now i know that in some cars its not a good idea to run 100w bulbs, but will it be fine in the sc's? or is it a no no?
lmk
thanks
Old 02-26-12, 09:57 AM
TechGreek
TechGreek's Avatar
Are you referring to HID bulbs or regular halogen bulbs?
Old 02-26-12, 10:16 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
We have tables, blinds, and curtains..... might as well have 100w light bulbs.
TechGreek
TechGreek's Avatar
Don't forget pedobears
Old 02-26-12, 10:37 AM
Golden95SC
Golden95SC's Avatar
haha lol
no there not hids, just regular halogen bulbs,
they state that some cars are not able to handle 100w output
i really dont wana smoke out my harness
what do you guys think?
Old 02-26-12, 11:00 AM
Teal Sc400
Teal Sc400's Avatar
IMO... bad idea considering the low beam headlight W is 55 and highbeam W is 65.
Old 02-26-12, 11:19 AM
TechGreek
TechGreek's Avatar
Personally, I wouldn't. I'd return them and get HIDs.
Old 02-26-12, 04:36 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
It's a very bad idea! You will most likely burn up your wiring and melt your headlight housing.
Old 02-26-12, 04:39 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I say heck no. The reason the wiring nor the plugs, being plastic could withstand the watts and heat in there. I put a 55 watt in the clear corner housing on the bottom of the front bumper. After 2-3 days, it melted the housing.. I could imagine what the 100 watt would do...
Old 02-26-12, 05:42 PM
maceugood
maceugood's Avatar
Dont do it! melted my harness with an 85 watt,
Old 02-26-12, 05:50 PM
xspsi6
xspsi6's Avatar
Exactly what will happen.
Old 02-26-12, 05:53 PM
sc-driver
sc-driver's Avatar
You're also wasting a lot of power in the form of heat too.
Old 02-26-12, 05:59 PM
MattStarr
MattStarr's Avatar
I'm not tryin to call you all out but honestly, some of the people on this forum really need to learn how research things before they go saying things as though its a fact. I do it too some times. Just sayin.......
Just because the original bulb is 55watts (actually oem is 51watts) doesn't mean you can't run a higher power bulb, but before doing so, it would be recommended that you replace the headlight relay and headlight fuses with whatever amperage the new bulb requires.
OEM headlight reflecting bowls are generally made to withstand up to 400° depending on the type of material used in the construction. The SC's low beam projectors and high beam reflectors are made out of aluminum and can withstand much higher temperatures than the urethane fiber construction that most other headlight projectors and reflectors use.
At most, a 12V 100w bulb will run at about 280° which is well within the oem headlights temperature handling range.
I actually ran 85w PIAA's in my high beams for 6 months until I did my bi-xenon retrofit. And now my cousin, who bought an SC300 back in October, has been running the same 85w 9005 PIAA's in his high beams and 100w 9006 Hella's (which suck BTW) in his low beams since the day he bought the car and neither of us have ever had a problem. No burns, no melting, nothing.
If you do decided to go with a high powered halogen bulb, go with the PIAA's. The Hella's suck compared to them and all the other brands are just a waste of money.
But to be completely honest, you can get an HID kit from DDM Tuning for less than what a pair of PIAA's will cost. I would, however, strongly suggest that you get a pair of PIAA's for your high beams. You'll be extremely impressed.
Old 02-26-12, 06:04 PM
MattStarr
MattStarr's Avatar
That happened because those old corner lights are made of abs plastic instead of urethane fiber, which is what the 95-96 and 97-00 fogs are made out of
Old 02-26-12, 06:11 PM
MattStarr
MattStarr's Avatar
You should go read a book about ohm's law. And also look up what a "watt" is. 1 watt = the conversion of 1 joule per second into X. X = something (light, heat, sound, ect.)
Quick Reply: 100w bulbs in our cars a bad idea?
