SC- 1st Gen (1992-2000)
Voltage drop when brakes applied.
Old 02-23-12, 04:02 AM
Drofseh
Drofseh's Avatar
Default Voltage drop when brakes applied.
Hey there. I am having a little electrical trouble. Whenever I put on the brakes I am getting a voltage drop. It's not bad enough to make my lights flicker but my battery light will come on after several minutes of driving. I figure I probably have a bad ground somewhere in the car. I have diagrams that show all the grounds from console to the tail lights but I am missing the page for the ones under the hood.
Does anyone have a diagram like this one for the SC400?
Old 02-23-12, 04:12 AM
spoolxexo
spoolxexo's Avatar
First how do you know? What do you have a multi meter hooked up going down the road?
Second, grounds don't usually "Lightly go bad", either your ground is completing the circuit, or it's not and you'd notice.
The battery light on your dash is connected to the 12v+ switch in the alternator to tell it to charge the system.
IF the warning light comes on, it usually means there is a short at your alt, as its the only thing it's connected to.
Old 02-23-12, 07:56 AM
scviolence
scviolence's Avatar
last time my batt light flashed like your describing my alternator died a day later...
Old 02-23-12, 08:26 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
It's in your battery cables, likely in the actual cable itself inside the clamp.
Old 02-23-12, 09:19 AM
Tabaka
Tabaka's Avatar
My RPM's drop about 200 or so when I press on the brake. I cleaned all of the grounds, got new connectors, purchased a new battery, etc. It didn't change anything. If you figure it out, let me know.
Old 02-23-12, 10:03 AM
GS4_Fiend
GS4_Fiend's Avatar
Do a voltage drop test on your battery cables. Make sure connections are tight. Get your battery load tested and what is your charging voltage?
Old 02-23-12, 12:30 PM
88supramki
88supramki's Avatar
Bad grounds, the car is notorious for it. Get a new neg cable, and check to make sure you have good quality ground points in the engine bay. I did one of the expensive grounding kits years ago, and I am going to ditch it soon when I get a chance to replace my neg cable
Old 03-04-16, 05:28 AM
LS400Club
LS400Club's Avatar
Default 1/2 Solved
My LS had a voltage drop every single time I pressed on the brake pedal. The lights would dim and the a/c fan would slow then speed up again as the alternator would return power. I noticed my vehicle stopped this crazy behavior directly after I replaced all 6 of the taillight bulbs with 1157 red Sylvania leds straight from Wal-Mart. No longer does the voltage drop when I hit the brakes.<br/>
immax01
17
04-30-12 09:21 PM
dougie23
07-17-11 11:20 AM
eurodirver
14
11-17-10 07:58 AM
jinhanyu
Performance & Maintenance
08-12-03 08:35 PM
lionj
02-22-02 06:03 PM
Quick Reply: Voltage drop when brakes applied.
