SC- 1st Gen (1992-2000)
Airbag on my steering wheel
Old 01-24-12, 08:17 PM
CrispyST3
CrispyST3's Avatar
Default Airbag on my steering wheel
Hey guys, i just wanted to know how i can pop out the air bag from the steering wheel, I need to get to the nut that holds the steering wheel to the steering shaft and torque it down.
My steering wheel is loose and it shifts from left to right while i'm driving but the tires don't move with the wheel. It will catch on after a couple degrees that i turn the wheel and then the tires themselves will turn. It's quite annoying and dangerous haha.
So if anyone can help that would be great. Thank you
Old 01-24-12, 08:25 PM
greens14
greens14's Avatar
make sure you disconnect battery terminal.
use T30 bit in wrench or screw driver, whatever you prefer. four bolts will allow you to remove steering wheel air bag.
theres 2 clips behind that, one for crews control, one for air bag.( a third which shouldnt be hooked up ...for carphone)
Old 01-25-12, 07:50 PM
WadeLovell
WadeLovell's Avatar
As Greens14 says, be certain to disconnect the battery. After doing so, for good measure, step on the brake pedal for ten seconds or so.
There are two pop out half moon shaped discs, one on either side of the steering wheel. Under those are the two T30 head screws. They are captured in the black plastic around their heads. There is no need to get them out, just back them out to the point where they are not holding onto anything.
The electrical connector is hinged. Be careful with it so you don't damage it.
Old 01-25-12, 09:33 PM
poorsupra
poorsupra's Avatar
a quick good search will pull up a full DIY with pics if you still need some help. just replaced mine with a black soarer non-airbag wheel last week =]
Old 01-27-12, 04:25 PM
matrixgts
matrixgts's Avatar
pull it up on you tube.i did last summer,i watched video went to auto zone and got a steering wheel puller.it has every thing you need,you use it and they give you your money back when you return it.pretty easy.make sure you disconnect your battery and wait a half hour to be safe.
Old 01-27-12, 07:03 PM
Tabaka
Tabaka's Avatar
I bent the bolts on my rented steering wheel puller lol
Old 01-27-12, 11:52 PM
poorsupra
poorsupra's Avatar
i didnt even use a steering wheel puller. i shimmy left to right and it popped off. dont shimmy up and down due to the tilt mechanism.
Old 01-27-12, 11:56 PM
Cleanshots
Cleanshots's Avatar
hit around the wheel.. or grab the top and pull it hard with a jolt.. maybe thats just cause im so badass.. lol
Old 01-30-12, 04:20 PM
CrispyST3
CrispyST3's Avatar
Lol thanks guys i'll be sure to try it once the driveway isn't full with cars -_______-
Btw does anyone else have the problem that i have? Or had?
AlaskaUSA
03-02-14 05:49 AM
is250fsprt
IS - 1st Gen (2001-2005)
01-19-14 11:44 PM
angmedic91
11-01-09 08:34 AM
Zagman91
01-17-09 02:30 PM
Quick Reply: Airbag on my steering wheel
