SC- 1st Gen (1992-2000)
SC400 door lock problem...
Old 11-15-11, 07:42 PM
718murdoc
718murdoc's Avatar
Default SC400 door lock problem...
Hi everyone,
My door locks on my 92 sc400 will intermittently lock by itself without touching the switch. I don't know why it's doing this. Could It be a ground issue somewhere? Any insight would be appreciated.
Old 12-12-11, 05:48 PM
718murdoc
718murdoc's Avatar
Also is there a way to disable the power locks to prevent the car from locking itself for the time being while i get a chance to have it looked at ?
Old 12-12-11, 06:33 PM
scguy
scguy's Avatar
U can unplug motores and lock and unlock maunely
Old 12-12-11, 07:00 PM
718murdoc
718murdoc's Avatar
I thought about just unplugging the actuator but i'm wondering if the security will still be triggered.
Old 12-12-11, 07:45 PM
mktbully
mktbully's Avatar
possible faulty switch? you have another driver's side switch to test with?
Old 12-12-11, 08:52 PM
718murdoc
718murdoc's Avatar
That's what I thought it was at first. I unplugged the master switch and with it disconnected it still locks intermittently.
Old 12-13-11, 12:21 PM
kln552
kln552's Avatar
Ha - mine does the same thing, but fortunately, never with the keys in the car. Frequently, I'll pull into the garage, lock the car, go in the house. Then I'll think of something I need in the car and hit the unlock switch. Go out to the garage, and just before opening the door, damn thing locks itself. Happens all the time, no idea why, but since it only does it when the key fob is outside the car, haven't worried much about it.
Old 12-13-11, 07:25 PM
718murdoc
718murdoc's Avatar
I really wish I knew why it does this because as I drive, the power locks keep locking themselves over and over. I swear it feels as if someones playing a joke on me with a remote key lol.
Old 12-14-11, 06:31 AM
718murdoc
718murdoc's Avatar
Can all the symptoms I described be caused by a faulty remote key receiver?
Old 02-04-13, 09:58 AM
crew chief
crew chief's Avatar
Did you ever find the problem?
Old 02-04-13, 09:56 PM
SCMike87
SCMike87's Avatar
OH OH OH... PICK ME!
I just had this problem... SAME problem. Driving down the road my locks would freak out by themself. Locks and windows would intermittently work.
You... my good sir... have a broken wire in the door loom. Its kinda a pain in the ***, but you have to take the door panel off, unplug the 3 connectors in the left kick panel that go through the body to the door. pull the wires all the way through.. peel the rubber cover back, cut the factory electrical tape and find the broken wire. Repair the wire (you may need to add a small piece of wire so that its not too tight) tape the **** out of it and call it good! Fixed mine 2 weeks ago, and havent had a problem since.
Old 03-17-13, 08:48 PM
SCMike87
SCMike87's Avatar
did you ever fix your issue??
Bizangel
02-18-13 09:19 PM
denverdog
09-16-11 03:53 PM
kendunk21
02-07-11 02:40 PM
dsiebert
09-17-10 10:52 AM
Quick Reply: SC400 door lock problem...
