sc300 1jzgte wont crank? Was running fine...
i have a 97 sc300 1jz r154 swap...it was running fine until today it shut off while driving and wont even crank fuel pump doesn't even come on.
It had a leaking power steering hose, dunno if that dripped on some sensors or wires and caused a short? But I checked the batt and the fuses in the engine bay and all connections.
What could it be ? Blown igniter? bad ecu ( I just fixed all capacitors on it not too long ago). The car wont even crank so something isnt getting power..thanks
gte & na-t
You shouldn't have bent Valves if you timing belt breaks, if your engine is bone stock i just cant imagine the previous owner of the engine put some aggressive cams with high lift..
Did you do a compression test? did you pulled the head off? it's just seems weird to me ..
ppayne1201
SC- 1st Gen (1992-2000)
11-17-13 02:35 PM
