SC- 1st Gen (1992-2000)
3 Spoke Steering Wheel - Single to Single Stage Wiring Issue
Old 09-12-11, 11:26 AM
iridebmx
iridebmx's Avatar
Blue is power, yellow is ground on that airbag connector.
the SC's red is power and the black is ground btw.
http://www.6gc.net/forums/index.php?...hreaded&start=
such a fast google search.....
that'll be TEN DOLLAA fee!!
Old 09-12-11, 11:28 AM
Tabaka
Tabaka's Avatar
Originally Posted by Kira X
Oh, I didn't realize your air bag didn't have that plug. Your best bet would probably be to solder the wires.
Has driving your SC without an air bag given you any trouble?
you mean like turning off when at idle? lol. If so, then yes. I don't think that effects it though. Lots of people get Nardi or aftermarket steering wheels and don't have issues.
Old 09-12-11, 02:40 PM
Mortal300
Mortal300's Avatar
ISSUE SOLVED! (MODS REFER TO THIS THREAD!)
The wires match up as follows.
BLACK to YELLOW
RED to BLUE
Confirmed by using volt meter to check which is power...
Old 05-10-15, 07:37 AM
megamax
megamax's Avatar
bump!!! mortal did you keep the sc hub? and what did you do to connect the horn??
Old 05-10-15, 11:01 AM
LoveSCs
LoveSCs's Avatar
I also replied to your response in the IS300 wheel thread. I will here too. I installed an IS200 wheel onto my 95 sc400 not too long ago. I left the SC hub on, and bought the airbag sub harness connector to adapt the SC clip to the clip on the IS wheel. I also cut the wires for the cruise control because I don't use it.
connector adapter is part number 09082-00760. I bought it from handsontools.
For horn, just cut the wire that I think is riveted to your SC wheel. Install a female spade terminal, and connect it to the male tab on the celica wheel (you will see the male tab in your pic of the celica wheel in the IS300 thread)
Old 05-11-15, 06:25 AM
megamax
megamax's Avatar
well I got the connector worked out soldered 2 pigtails together so save 30 bucks.
and in terms of the horn, can you save the pic of the sc400 wheel I have posted, go to windows paint and draw a line to what I need to do for the horn??
ill give you a dollar. thank you
Old 05-11-15, 02:03 PM
LoveSCs
LoveSCs's Avatar
nice. I was hesitant on splicing the airbag harness. Just in case I ever need it, I want to make sure it works.
Here is the pic of the horn wire. It is riveted/soldered on. Snip it, strip it, and crimp on a female spade connector:
Here is the pic of your 3 spoke wheel. Connect the above crimped spade connector black wire to the tab that the yellow wire is connected to in pic:
haha, and keep your money bud. thanks anyway
Keith
Old 05-11-15, 08:25 PM
megamax
megamax's Avatar
Thank you keith, you rock!!!
Old 05-12-15, 03:25 AM
LoveSCs
LoveSCs's Avatar
You're welcome!
Old 05-12-15, 05:32 AM
megamax
megamax's Avatar
so since I don't need cruze control or the car phone I can go ahead and snip that black and green, and that blue sleeved wire?
Old 05-12-15, 10:19 AM
LoveSCs
LoveSCs's Avatar
yes, that's what I did. Just snip them in the middle of the wire length just in case you ever wanted to re-install it
After snipping the wires, individually heat shrink the ends of the wires to insulate them. Also, I disconnected the battery while installing the wheel because some people have mentioned the airbag light coming on if the airbag harness was disconnected while battery still on.
- V -
06-12-12 06:28 PM
SCVIP300
SC400 / 300 Classifieds
12-16-10 09:02 PM
amcdonal86
03-19-10 10:09 PM
SC904
10-11-08 04:08 PM
DJ SprinklesNJO
12-01-04 07:24 PM
Quick Reply: 3 Spoke Steering Wheel - Single to Single Stage Wiring Issue
