SC- 1st Gen (1992-2000)
SC300/400 owners ... are you still buying premium gas for your car?
Old 08-19-11, 11:33 AM
lexdud
lexdud's Avatar
Default SC300/400 owners ... are you still buying premium gas for your car?
I am ... but I saw this article on 12 things you should stop buying and one was premium gas ... unless you own a Ferrari:
http://moneyland.time.com/2011/08/19...mium-gasoline/
I request your opinion as it would be great to buy the lesser grades if it would not be detrimental to my near-pristine (56K miles) 1993 SC400 motor.
Old 08-19-11, 11:45 AM
MikeSC
MikeSC's Avatar
I have a 92sc400 and I tried a lower octane fuel once.The motor reacted badly....pings,no get up and go.For the 20 cents extra per gallon the premium is worth it.Nice sc ,BTW.
Old 08-19-11, 12:00 PM
shboni
shboni's Avatar
yup...
lexdud
lexdud's Avatar
Good to know ... thank you.
Old 08-19-11, 12:42 PM
xspsi6
xspsi6's Avatar
Mid grade is more than enough, No need for 93.
Old 08-19-11, 12:48 PM
TechGreek
TechGreek's Avatar
Enjoy the carbon deposits in your motor, and wondering why you have no power.
You'll get LESS hp on an already sub-par 200"ish" WHP N/A version of a 2JZ, and then you'll have to push the gas even further to accomplish the same acceleration you naturally accelerate at every time.
If your car calls for premium, it's because the ignition timing,etc has been optimized for it. If it doesn't, you're wasting your money throwing 93 in it.
I would love to see someone come to LA/TX in this heat and try to run 87 in an SC300 and see how fast it detonates at stock ignition timing.
Old 08-19-11, 01:10 PM
cmh
cmh's Avatar
on my 1995 sc400 i only use 93 octane, but i just bought a 97 sc400 and the guy told me he puts in 93 octane every 2 tanks otherwise he uses the cheap one. call me crazy but my 95 has way better throttle response and is way faster and thats that the 97 is supposed to have like 10 more HP. i think its the gas so im waiting till i run out all the way to put the better gas in it to see if it runs better... DONT USE CHEAP GAS...lol
Old 08-19-11, 01:25 PM
spdrcr771
spdrcr771's Avatar
Yea I only run 93, & I tried to run mid grade back when 93 was $4.22 a gal. Didnt have good results, especially with the SRT chip leaning it out.
Old 08-19-11, 01:59 PM
TRDmike
TRDmike's Avatar
About gas, does anyone go to specific gas stations? For example, I only go to shell for my turbo SC, but tried putting another unknown brand and car started knocking and had problems starting until i used Lucas octane booster. Although, it was tuned with shell 93 v-power.
To add on to the topic:
would it benefit getting 93 from shell or chevron with their special additives on a stock motor or any 93 rated gas will do?
What is everyone's input on this?
Old 08-19-11, 02:07 PM
jadu
live.love.laugh.lexus
jadu's Avatar
shell 89 for me: http://www.fuelly.com/driver/jadu/sc300
INTIMAZY
INTIMAZY's Avatar
On N/A cars (especially older, low compression designs) there is no discernible difference between high vs low octane. If an ECU doesn't detect enough knock to pull timing, there will be NO effect on power.
In modern high compression motors it can and DOES make a difference (I personally spent some time back in 2009 in a pre-production Corvette ZR1 that was being low octane tested) Many ECU's will pull significant timing in response to knock.
That being said, on my stock NA 2JZ I ran both. No difference that I noticed. My motor didn't blow up. Passing power was not affected. Ran nearly 220,000 miles without problems before the motor got swapped.
On my 1JZ? I'll only run premium
Old 08-19-11, 03:00 PM
yOitzsean
yOitzsean's Avatar
91 for me always... I've been using Chevron gas for years and I've had good luck. I also use the Techron fuel system cleaner twice a year... Techron is the **** man. But if I'm poor, I will get a few gallons of 89 ^^
Old 08-19-11, 04:06 PM
xspsi6
xspsi6's Avatar
Anything over 89 is a waste of money as the compression and timing are aggressive enough to warrant anything more but we are talking pre vvti here.
Old 08-19-11, 06:05 PM
Joey-E
Joey-E's Avatar
So this topic comes up again....i will always use premium 91+ (93 for me) as the owners manual recommends and warns otherwise.
Old 08-19-11, 07:14 PM
jwb9
jwb9's Avatar
Default 93 octane
The SC400 has a high compression engine. It should be run on high octane gas.
Iv'e been using 93 octane BP gas in my 99 SC400 and my 2001 solara V6. The Solara has 200,700 miles on it and I still have to look at the tach to see if the engine is running. Feed it good and it will run good, feed it crap and it will run like crap.
I tried cheap gas for a few tank fulls, performance and milage both suffered.
There really wasn't any savings.
Quick Reply: SC300/400 owners ... are you still buying premium gas for your car?
