Post Pics of Widebody SCs only THREAD
#76
I'm the owner of the white SC you're referring to. As far as specs:
F: 19x9 (-7 offset) 245/35/19 (+5mm spacer to clear 8-piston calipers)
R: 19x12 (-7 offset) 325/35/19
I eventually downgraded the tire size to a 295/35 in the rear and 235/35 in the front due to rubbing under full acceleration/ deceleration and fast turning.
#77
For the guys running wide body rear fenders I have a question. I have the vertex wide rear fenders and the car came with 18x10 -9 on a 275/35. I need way more tire in the rear. What size rear wheel and tire combo are you all using? Can you include offsets also? I would like to go to a 19 just trying to get an idea of what will clear on the rear. I know I have a decent amount of space to go in towards the shock tower. So if ya can help me out please do so.
Thanks
Thanks
#78
I'm actually running fiberglass fender flares for the front and rear. The original metal behind the flares were cut/trimmed for clearance and the inner fiberglass fender lips were reinforced with a bit of metal to prevent cracking at the edges (front and rear).
The brand names escape me at the moment, but the fronts were 25mm and rears 50mm (rears were 'Missle').
I appreciate the love on the setup. It's not for everyone, though. If you've ridden in it, however, it's setup like that for a reason and you'd quickly understand
Another photo can be found on the shop's instragram I had it finished at (FSR Motorsports Creations):
https://www.instagram.com/fsr_motorsport_creations/
#82
Thanks bro, Im looking for a wider wheel like this, im trying to get a good fitment for a fender roll before the car is painted. Do you know of any other wheels like this style that are a little easier to find Im looking for something about 3/4" - 1" of an inch out from the stock quarter.. Any similair style wheels?? Ive only came across a couple
#83
GiantsFan
35
08-15-13 06:41 AM
