SC- 1st Gen (1992-2000)
1jz to what engine is best
Old 04-02-11, 06:34 AM
ckja
ckja's Avatar
Unhappy 1jz to what engine is best
1jz_2gz or 2JZ-GTE VVT-i which engine is easier to put in a 1992 toyota Soarer I have 1jz but want to go newer engine or keep my 1jz what you guys think i should do
Old 04-02-11, 10:00 AM
lookEVO
lookEVO's Avatar
rb26dett
wut?
Old 04-02-11, 10:50 AM
Relapser
Relapser's Avatar
What is wrong with your current engine?
There is nothing wrong with TT 1j. Be happy with what you've got dude.
If you want. Install a new turbo kit on it. Run higher boost. And replace the ecu capacitors... It will run like a brand new car if you do.
But for god sake why do an engine conversion...
If you must, do a 1j vvti... Personally I see nothing with the tt
Old 04-02-11, 02:25 PM
attzor
attzor's Avatar
Get a single turbo kit and a good tune, and if thats not good enough, 1.5jz.
or k20 swap ?
Old 04-03-11, 05:19 AM
Relapser
Relapser's Avatar
1.5j into TT soarer is pain in the backside cos mounts are for 1j not 2j
So basically 1.5j is easy when car is made to have a 2j bottom end...
I would personally recommend the vvti 1j
But even that is a difficult swap afaik
Why would you go rb26dett??
Like why go to soooo much ridiculous effort to custom fit in a foreign manufacturers engine to go from a parallel TT 2.5ltr to a parallel TT 2.6ltr?
Makes no sense to me
Old 04-03-11, 06:16 PM
lookEVO
lookEVO's Avatar
i was joking maybe?
Old 04-03-11, 06:21 PM
JDMCelsior
JDMCelsior's Avatar
dude, keep your 1j and go single...by that i mean turbo, so don't go trying to divorce your wife or leave your g/f.
Old 04-03-11, 08:03 PM
Klaus
Klaus's Avatar
If you were starting with a 2jz-ge, the 2jz-gte would definitely be the better of the two options. But if you already have a 1jz, no sense ripping it out as there's still plenty of power on tap. Single your 1j, go with like a 6262 BB with billet wheel for spool. You'll love it.
Old 04-03-11, 08:38 PM
wickedsc3
wickedsc3's Avatar
Dude keep the 1jz and go single. unless you got like money to throw around then I would go with the 2jzgte + v160.
Old 04-03-11, 09:05 PM
97-SC300
97-SC300's Avatar
forget about the swap just ship me any TT engine you got and I will make room for it....
Old 04-03-11, 09:24 PM
Copilot
Copilot's Avatar
1jz with a single turbo with a good amount of boost would be awesome.
Old 04-04-11, 02:18 AM
Relapser
Relapser's Avatar
Not even single...
Here in Australia my friend tristan at WTFauto makes twin turbo kits for the 1j
Sequential bb turbo kits I might add
Old 04-04-11, 02:24 AM
Relapser
Relapser's Avatar
http://www.wtfauto.com.au/images/for...ns/twins22.jpg
^^^rooks rike dat. You rike it?
Imagine that size twin turbos on a 1j...
Stick THAT in your thread and read it.
And lookEVO - don't joke.. Someone has done a 26 into a soarer man..
In fact smokey nagata put an rb26dett into a supra...
Most unique swap I seen into a z30 soarer is the 20b quad rotor twin turbo... By those crazy loveable idiots at carshop eau rouge...
Old 04-04-11, 07:35 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Just give your 1JZ a refresh, new seals etc. larger single turbo and the rest of it.
Ejsides36
13
08-09-11 04:28 AM
sunrisetrd
Performance & Maintenance
12-04-08 01:32 PM
Lucky SC
23
11-29-06 10:50 PM
soarerxx
09-14-04 06:51 AM
Idrockasupra
19
04-11-03 06:01 AM
Quick Reply: 1jz to what engine is best
