SC- 1st Gen (1992-2000)
changed maf = supercar!!!!! explain
Old 03-17-11, 07:34 PM
Dade305
Dade305's Avatar
coming to the end of this thread and glancing at the title of it made me "lol"
Old 03-17-11, 09:37 PM
boney31
boney31's Avatar
how could i tell the other maf was bad? i only replaced it because it was cracked at bottom an turns out the replacement is to
Old 03-17-11, 10:00 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
I'm wondering the same thing? How do you know for if it's bad?
Old 03-18-11, 10:14 AM
mehsoarer
mehsoarer's Avatar
test it.
https://www.clublexus.com/forums/sc-...on-issues.html
Old 03-18-11, 05:14 PM
WingsofWar
WingsofWar's Avatar
If your car has a defective or already deteriorating MAF chances are by replacing the MAF with a new one will regain some of that performance and economy you have lost.
However is true for many car makers if you replace a MAF with a larger diameter, you could increase the power a little further. The 240sx guys tend to get MAFs from Z32/R32-34/ even the mustang 3.5 inch diameter MAF provided a increase in low end TQ on the dyno.
How it pans out for the SC300/SC400 im not to sure, I haven't done a search on it yet.
Old 03-18-11, 07:49 PM
boney31
boney31's Avatar
i only replaced the sensor
Old 03-19-11, 12:49 AM
Akito san
Akito san's Avatar
i wonder if there is a Maf swap upgrade for 2jz
I have a Q45 n90 Maf on my Nissan
Old 03-19-11, 01:09 PM
evopanop
evopanop's Avatar
Is there a larger MAF that the SC400 people can use? Anyone know?
Old 03-19-11, 02:19 PM
drft_n_sc
drft_n_sc's Avatar
I know the v8 MAF has a larger housing and is a direct plug in on the 2jz motor
I also know that the 2jz guys can upgrade to 440cc injectors and the 1uz MAF for a quick and easy power upgrade and if you have a SAFC you can maximize the performance boost
Old 03-19-11, 03:25 PM
evopanop
evopanop's Avatar
Is there anything like that, that the SC400 people can do?
Old 03-22-11, 06:06 PM
boney31
boney31's Avatar
Default comparison
guys i bought a new fmz3ayy2(a working one) an compared it to fmz3ayy1 an heres how she shapes up.
fmz3ayy2
pros:
super smooth ride
smooth shift
clean engine sound
50-100 soft peddle easy acceleration
cons:
lag from take off
lag from getting off her then getting back on her
fmz3ayy1
pros:
very powerful(normal feels like power, power feel like u r driving a truck)
1-3 gear shift is fast(acceleration is night an day)
down shift so quick that at high speed u can get off her then back on with no lag!!!!!
mpg
50-100 harder peddle but feels like u r in complete control of car
cons:
engine sound
feel road more but still pretty smooth
down shift hard as hell when coming to complete stop or coming down a hill
Old 03-22-11, 06:57 PM
horent135
horent135's Avatar
Will the V8 MAF work on the 98 SC300?
Old 03-22-11, 07:32 PM
BenStoked
BenStoked's Avatar
the thing about the 1uz maf on another motor is not the sensor, but the size of the housing. the jz/7m housings are about 1/8-1/4 inch smaller diameter. larger diameter=more air in. upgrade the injectors at the same time, or you'll go lean, really, really badly.
7mgte and 1uz sensors are the same. I believe the 2jzgte has the same sensor, too but haven't worked on one to be sure.
Old 03-22-11, 08:16 PM
MongooseGA
MongooseGA's Avatar
Jan
fmz3ayy2
pros:
super smooth ride
smooth shift
clean engine sound
cons:
lag from take off
fmz3ayy1
pros:
mpg
cons:
engine sound
How would the maf affect how much of the road you feel?
Old 03-22-11, 08:27 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Easiest way to test a MAF is simply to unplug your battery for an hour.
Your ECU will reset and have to take new readings. If it runs the same, your maf is good. If it runs like crap your maf is bad. The ECU runs off the cache memory in the ECU for it's baseline settings, it only adjusts fine increments from the MAF as you drive. When it has to completely reset, it won't come back alive so well if the MAF is in bad shape.
Quick Reply: changed maf = supercar!!!!! explain
