19x8.5 offset30 19x9.5 offset15
Fridays comin and I'm pickin up these wheels and throwin them on, already test fitted and I love em. Ill keep this thread updated....ill have pix of my current 17x7 17x8 +45 setup later today and the pics of the drastic change by Friday.
I'm still having a debate about fender roll vs shave.
For sure i need fender mods of some sort but which will create more clearance?
If shaving can create the same clearance as rolling I want to save the money
And shave em myself. I can always get a roll or pull after that anyway right?
15 offset is pretty low but itll fit, you need to roll your fenders flat on the inside and maye a slight pull, as far tire size go you might able to get away with 255 the biggest,
a shave wont cut this unless u plan on running like a 235 tire stretch. Shaving is a good idea a slong as its not cut right where the lip meets the fender. Fendering rolling be best after that cause shaving causes sharp unsafe edges
wickedsc3
SC- 1st Gen (1992-2000)
16
09-26-09 06:27 AM
