would this pioneer fit?
looking to upgrade sound in the sc. came across this:
Pioneer In-Dash DVD/SD/USB Receiver with 7" LCD, Bluetooth & GPS Module
would this actually fit without having to cut anything? says it fits single sized dash.
they have an online deal for $499 which includes the gps but i want to make sure it'll fit before buying. i priced these for 1000 bucks in the store.
* DVD/CD receiver with internal amp (14 watts RMS CEA-2006 / 50 peak x 4 channels)
* 7” motorized touchscreen with multi-angle adjustments
* Built-in Bluetooth for hands-free calls
* Intuitive touchscreen controls
* Five customizable display colors and 112 key panel illumination choices
* Fits single-sized dash openings
* Plays MP3/WMA/AAC files recorded on CD and DVD
* Supports video playback from DVD, DVD-R, DVD-RW, DivX, and Video CD discs
* 8-band graphic equalizer with Auto-EQ
* High- and low-pass filters
* Dual-zone output
* Bass boost
Pioneer Add-on Navigation System:
* Coverage Area: US, Alaska, Hawaii, Canada, Puerto Rico
* Points of Interest (POI): Approx. 0.4 Million
* Display Modes: 2 (2D/3D)
Specifications:
* Chassis Size Code: IEJ
* CEA-2006 Compliant: Yes
* RMS Power Output: 14 watts
* Peak Power Output: 50 watts
* RMS Power Bandwidth: 20-20kHz
* Preamp Outputs: 6-channel
* Preamp Voltage: 4 volts
* Subwoofer Preamp Outputs: Yes
* Monitor Size (diagonal): 7”
* Retractable Monitor: Motorized
* Key Button Color: Variable
* EQ Bands: 8
* Sound Shaping Type: EEQ
Tuner:
* Tuner Type: Supertuner IIID
* FM Sensitivity: 9 dBf
* FM Presets: 18
* AM Presets: 6
* Radio Data System (RDS): Yes
DVD:
* DVD Frequency Response: 5-44,000Hz
* DVD Signal-to-Noise: 96 dB
* DVD Formats: DVD-R, DVD-RW, DVD
* MP3 Disc Playback: Yes
* WMA Disc Playback: Yes
* AAC Disc Playback: Yes
Additional Photos:
* Pioneer In-Dash DVD/Radio with GPS unit
* Pioneer Radio Screen
* Playing a Movie
* In-dash Unit Closed with Front Buttons
* Front Faceplate Removed
* Front SD card Slot (SD Card NOT Included)
* GPS Unit with Included Mount
* GPS Unit Connections
* GPS Unit out of Mount
* Tip SD Card Slot and Mini USB Port for Easy Updates
* Package Contents
* Retail Package
In the box:
* Pioneer AVH-P5200BT In-Dash DVD/Radio
* Pioneer AVIC-U220 Add-on GPS System
* Antenna Adaptor
* In Car Microphone for Blutooth
* Wiring Harness
* GPS Cable
* GPS Antenna
* Mounting Hardware
* Dual-zone output
* Bass boost
Specifications:
* EQ Bands: 8
Tuner:
* FM Presets: 18
* AM Presets: 6
DVD:
Additional Photos:
* Playing a Movie
* Package Contents
* Retail Package
In the box:
* Antenna Adaptor
* Wiring Harness
* GPS Cable
* GPS Antenna
* Mounting Hardware
If by single they mean single-din then yea it will fit. But you'll have to fill the remaining hole with a tray or something..
Single-din and doubble-din will fit SC's without cutting. I dont even think another size exists unless its some wierd headunit that fits somewhere in between single and doubble-din.
lightwave76
04-27-14 10:42 AM
vince1128
11-23-06 08:08 AM
