SC- 1st Gen (1992-2000)
How much did you pay for your manual swap?
Old 11-17-10, 12:55 PM
Novoken
Novoken's Avatar
Default How much did you pay for your manual swap?
So in 2-3 months ill be doing a w58 swap. Dont have the time or tools to do it myself so I need to bring it in to a shop. How much was labor for you guys? How much did you guys pay and how long did it take? I plan to take the car and all the parts to the shop or if I find someone where that would do it thats local that would be great.
Old 11-17-10, 01:24 PM
1SICSC4
1SICSC4's Avatar
Parts will run between $1500-$2000 labor will probably cost you close to the same. It's a somewhat easy swap that you could do your self but a shop will rape you because its a "custom install". Talk to RedPhoenix he co-owns a company called Quantum Automotive that makes an adapter for the sc400 w58 swap and is probably one of the most knowledgeable people on the subject.
Old 11-17-10, 01:37 PM
Guest
Guest
Posts: n/a
i spent about 3k my r154 swap did all my work my self. so my be about 2k in parts complete parts for w58 that is with new stuff like clutch lines pedals clutch ect ect.... mybe 1500 for some used stuff. if you think you can do it your self trust me you can if you just studdy it here on the forum and have someone help you.
Old 11-17-10, 01:59 PM
kyddo112
kyddo112's Avatar
I've seen a couple of w58 tranny's in the f/s section from $300 to a complete swap for about $2k.
I was in the same boat as you but just ended up selling my 97 auto and buying a 92 5spd with less miles and in better condition. Also came away with $1k in my pocket afterwards.
Old 11-17-10, 02:23 PM
CP_Ree
CP_Ree's Avatar
I'd just find a manual and buy that if you're going to pay someone to do it. I had a 97 white SC and sold it to buy a manual 97 (because the 97 5spd's are rare and I didn't want to do the work)
Old 11-17-10, 03:33 PM
BartleDoo
BartleDoo's Avatar
Yea, definitely don't bring it to a shop for the swap (rhyme time).
Old 11-17-10, 07:58 PM
Novoken
Novoken's Avatar
I got a quote for $650 for the labor about 3 hours from where I live. Really didnt want to pay more than $500 for the labor. I was thinking about selling it and buying a manual, but cant find one. Needs to be dwp or black. Heck ill take anything but green.
Old 11-17-10, 09:37 PM
SChema
SChema's Avatar
Quite honestly, $650 for a swap is not that bad. I'm assuming that labor includes everything from dropping the auto to installing the pedals?
Old 11-17-10, 10:13 PM
BartleDoo
BartleDoo's Avatar
Oh the clutch pedal! Don't remind me!
Old 11-17-10, 10:33 PM
masagsxr
masagsxr's Avatar
I don't think the labor will cost that much. Local shop replaced a clutch, flywheel etc on my 88 RX7 Turbo II once (way way way back when I didn't know jack hahaha) and cost me about $400 (parts and labor). Then again, thats a while back. I don't see it to be much different with auto to manual.... I would definitely do half of the job tho like taking off the center console, installing the clutch and brake pedal as well as the clutch master cylinder then drive the car to the shop.... Give the shop a little guidance as there is really a couple of things they'll wire up like the neutral switch. Everything else should be plug and play considering you did your part on the research and gather absolutely all the parts you need.
Good luck.
Old 11-18-10, 12:41 AM
xxtoobsxx
xxtoobsxx's Avatar
Will the auto sc300 rear drive shaft work? Also did you use the howe bearing or quarter master? I have the howe...need a shaft, flywheel and a clutch and im all done!
Old 11-18-10, 04:32 AM
7sins
7sins's Avatar
This is an easy swap! Don't pay someone to do it! If you don't have the tools go to the flea market. You'll get everything you need for a few bucks. Anyone with common sense could do this swap in a day. I'm just sayin..
Old 11-18-10, 04:48 AM
BenStoked
BenStoked's Avatar
f*** the flea market. if you think you can afford a shop, you can definitely afford the good tools to diy.
but, yeah, $4000 sounds about right
Old 11-18-10, 05:12 AM
RyanV
RyanV's Avatar
FYI, I have a 95+ W58 swap if anyone wants it.
95+ Sc300 W58
Sc300 5spd OEM driveshaft(hardest part to find)
Competition Clutch
Short shifter
new oem slave, t/o bearing, flywheel bolts
Old 11-18-10, 05:25 AM
scmissle
scmissle's Avatar
If you look in the right places you may be able to get prices down a few notches. What parts do you have right now? A buddy of mine has a W58 he will sell complete(transmission, clutch, flywheel, new throwout bearing, slave and masters) for $200.
Quick Reply: How much did you pay for your manual swap?
