You wouldn't happen to be able to get any installed pics would ya? How many mounting bolts hold yours on? The only 2 that would line up are the 2 MC bolts.
Yeah from the looks of it, there is no way in hell the top bolt even comes close. When I had the pedal on the MC bolts it was basically hitting the floor (with pedal in up position) and the top bolt hole was about 3 inches away.
Just to clear up the confusion, the Supra clutch pedal/bracket does NOT fit SC300's. I was out in the garage for about an hour trying to install the clutch pedal on my 92 SC3, and the mounting pattern is definatly not the same (besides the 2 MC bolts).
When installed just on the MC bolts the clutch pedal is unable to be depressed(hits the carpet). I even removed the "dead pedal" and still no bueno.
I bought the pedal from a guy in Japan, but im 90% sure its NOT off a JDM (rhd) supra, im sure he would have mentioned that.
So I guess its back to the hunt of finding a SC300 clutch pedal!!!
Ok my pedal is not in steel ,it's in aluminum only the bracket is steel.
Can you read me the part# of the pedal and the bracket? i can tell you if it's RHD or LHD.
OK, there are NO part #'s on anything. The only numbers/letters were on the pedal itsself. It read " AF " Thats all.
Ok i will take the pics of mine when i get home, but it does look like a RHD pedal not saying it is, but will see.
Like i said mine was made out off aluminum.
